My 350 Is Still Using Oil Somewhere - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-23-2004, 06:58 AM
HJCHEVY400's Avatar
When Cool Meant Cubic Inches
Thumbs down My 350 Is Still Using Oil Somewhere
Hi Everyone
I have a 350 Chev which has done about 1400 miles since a fresh rebuild. I have a problem with oil consumption. It seems to just keep on losing oil. I don't know if oil could be seeping into the combustion chamber through the intake gaskets, or if their is a ring problem. It doesn't blow visible smoke or anything through normal driving. But if I give it some from the traffic lights, I can see a swirly haze in other peoples headlights. I'll even leave it overnight to check the oil level, and it is lower and lower every day. It seems to lose oil at a slower rate if I take it easy load and revs. I've checked if the PCV is sucking oil, and it seems to be clean.
Should my rings be run in by now?
I used Castrol GTX 15w-40 mineral oil for the run-in to 500 miles, and now am using ULX-110 20w-50 (thicker oil for our Australian summer.)
Specs : flat top pistons, moly rings, .040" overbore, standard rocker covers and PCV System.
Old 02-23-2004, 08:12 AM
willys36@aol.com's Avatar
Wiki Edits: 21
It's blowing by your rings. Be patient, may take several thousand miles to stop sucking oil.
Old 02-23-2004, 08:33 AM
New Member
In 1978 I purchased a new camaro w/350 . I was going through 2 - 3 quarts per month & with out being that noticeable through the exhaust .I was 1st told by the dealer that the engine is breaking in . After complaining to GM they took the car & found that the valve guide seals were never installed . 55Mole
Old 02-23-2004, 12:07 PM
HJCHEVY400's Avatar
Thanks Very Much for your help, guys. I was just wondering Willys36, I was told by an engine builder that if the rings aren't bedded in as yet, that if it goes on for too many miles, they will never bed in, and oil use would be at a greater level.
Have you ever heard of or seen rings that don't bed in within a few thousand miles? Is it a common occurance?
Old 02-23-2004, 12:25 PM
Wiki Edits: 21
Well, I have heard those horror stories too, but in my experience I have never had an engine (a dozen or so) that didn't eventually seat the rings within a few thousand miles. I just don't worry about it 'cause it has been my experience that it fixes itself. Admittedly I am just a hobbyist so maybe an engine builder type can chime in here.
Old 02-23-2004, 12:31 PM
Magikal's Avatar
How can it go faster?
Last journal entry: Been a long Winter
From my experience it seems that the valve guides will smoke when changing gears (manual trans). I would take it out to the freeway and get it up to high speed/rpm... Perhaps there is some sort of additive that could be added to the oil to stop the leak??? No leaks, right?
Old 02-23-2004, 12:54 PM
Wiki Edits: 21
My experience with valve guides is that when they are going south there is a big puff of blue smoke on startup that soon goes away, even if the engine isn't using a lot of oil. Rings don't do that, they smoke while running, but not necessarily on startup.
Old 02-24-2004, 06:54 AM
HJCHEVY400's Avatar
Once again, I would like to thank everyone for their help.
What i'll do, is keep an eye on the oil level, and hopefully, it will come good after a few thousand miles.
Thank You
Old 02-24-2004, 10:54 AM
blndweasel's Avatar
paints everything flat black
Last journal entry: September 2005 - Current
When you had the engine rebuilt, did you re-bore or re-hone the cylinders? what kind of stones did they use in the honing process? For plasma-moly coated ductile rings, you should have had a relatively smooth bore finish after the honing process.
Did you have your bores measured at various locations up and down the bore, to check for straightness? the bores could have been round at the top, but distorted towards the bottom of the stroke, and the rings might not be sealing. Anywhere the bore is out of circle, your rings won't touch the wall of the bore and you'll get oil blowing by. Do a compression leakdown test. Get an idea of how well your rings are sealing.
my 2 cents
the blonde weasel
san diego, CA
Old 02-24-2004, 01:49 PM
club327's Avatar
I agree. If it was just a rering job then you'd need rings of cast iron type that are cut for quick bedding in. We don't know what's been done inside your engine. Take a look at all your spark plugs and look for any abnormal deposits/oily build up/crust. It could be just one cylinder that's giving you the problems. I have access to a borascope that allows me to look inside engines which is real handy. In your case Id remove the carb and with the scope look at the intake valves for oil build up below the guides. In your case manifold removal is needed to view of course. I remember being told by some rough mechanics that the've sped up the ring bed in process by pouring small amounts of Bon-ami cleaning powder down the carb' while the engine's running! Now I did'nt tell you that and I'd certainly would not try something like that myself. I gather there's no warranty on the motor so you either need to be patient or look further into the problem.
Old 06-06-2006, 12:44 PM
oil loss
Small blk chevys have a problem sucking oil from bottom of intake, what kind of intake and what intake gasket did you use .
Old 06-06-2006, 12:51 PM
sbchevfreak's Avatar
Licenced Automotive Technician
This used to be a service procedure! An older gentleman I know used to work at a Ford dealership in the early 60's, and that was what they were told to do! He also worked for Case/IH company as a mechanic/service manager for 16 years, and there were bulletins that recommended this as well. AFAIK, it is definitely not recommended anymore.
Old 06-06-2006, 02:13 PM
Mustangsaly's Avatar
My Dad told me Chevy advised the GM Dealerships the same thing for oil usage (rings not seating) on the 1st 265 V8s in 1955 up, and it worked. I'm thinking I would not want to do it then or today, butt hey it's a true storie. and he said most don't and won't believe it today.....
Mustangsaly
Old 06-06-2006, 03:17 PM
docvette's Avatar
Wiki Edits: 12
Doc here,
Another 2 year OLD thread...
Wonder if he ever got it resolved and How?
Doc
Aftermarket Solutions
Electronic & Electrical
Innovations
Old 06-06-2006, 03:20 PM
Shoot! I didn't even look at the post date! Is it just me, or are a lot of these old posts getting bumped lately?
