my 350 trans wont shift out of 1st gear - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-25-2011, 06:23 PM
Old 04-25-2011, 07:07 PM
no shift
ok first 2 things to check 1 are you getting vacume to modulator valve at trans.if thats good the 2nd thing to check is the govenor,theres a round cover at the back of the trans about 3in. wide with a clip on it remove the clip and tap it out with a screw driver and hammer,remove the govenor it slides out.they have a plastic gear that breaks
Old 04-25-2011, 07:26 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
86montecarlo;
welcome to Hotrodders.com
I edited the thread title. Please put more information in the title when you post a new thread. That helps the members here and the search function
Put a shift kit in and now wont go into gear? nova327 Transmission - Rearend 4 08-13-2010 03:30 PM
82 Cutlass. Wont shift out of 1st gear TheBigDeal Transmission - Rearend 1 03-12-2010 03:11 PM
700r4 wont shift out of first gear illegal regal Transmission - Rearend 33 02-08-2009 07:32 AM
4l60e First Gear Wont Shift chevy71z Introduce Yourself 5 08-11-2008 10:58 AM
T-350 trans, it wont shift jettajo42 Transmission - Rearend 1 06-15-2008 11:05 PM
