My 350 turbo just stoped working. - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-03-2012, 11:00 AM
it wont go in to any gear? i have a 71 step side and the trans was fine until the other day after i drove it for about 30miles.when i was ready to leave i heard a light rattling sound and when i went to put it in gear, "nothing". it won't go in any gear.i had to tow my truck home i checked fluid and made sure the shifter was hooked up to the trans.when i got home i noticed the vac line was off!. so i checked the flex plate and made sure the t.c. was bolted and every thing looked fine.i ended up changing the filter and fluid, i put the vac line on properly and i still get no responce from trans.i don't know what else to do but replace the trans.i dont understand how it would just stop all of a sudden.it was running fine it wasn't slipping or anything like that.any advice will be greatly appreciated.aloha and thank you for reading my post.
Old 01-05-2012, 12:15 PM
you splined out your torque converter these old 350 were bad about that replace convertor
Old 01-06-2012, 02:48 PM
would it just give w/no symptoms or sings? the tc i have on trans is blue, my friend told me its not the original tc. should i go get another one? this is good news for me, i think i may have a extra tc.thanks for replying.
Old 01-07-2012, 11:45 AM
when the convertor goes out it gets to a point it can no longer hold that is why in s truck most people uses a 400 t/q iys stronger better for pulling and mild performance use on street if the convertor you have is good use it if you have to buy one a 400 cov is stronger
Old 01-07-2012, 05:14 PM
It is possible that the manual shift shaft has come loose from the shift mechanism (so-called rooster comb) inside the transmission. It can be checked by disconnecting the manual shift linkage from the manual shift arm on the side of the transmission. If you can move the shift arm without feeling the detents for each shift position it is disconnected inside.
Old 01-07-2012, 05:26 PM
thats one of the first things i checked.its hooked up.i acually just got done pulling trans from motor.thanks for your response and any more would be great.thanks
Old 01-07-2012, 05:32 PM
i found out the trucks trany and tc has been beefed up for hauling race cars.that being said would you think its my tc? if so the extra one
Old 01-08-2012, 03:40 PM
i just bought a used trany and its to short.what a idiot
Old 01-08-2012, 03:47 PM
long to short
you know you can take your short shaft n make it a long shaft. i did it but its not easy. you have to take them apart.
Old 01-08-2012, 04:00 PM
by take apart you mean go into the tran? if so that might be to much for me to handle.what exactly needs to be done? i appreciate you're respond , thank you
Old 01-17-2012, 11:27 PM
now what? will it hold
ok i decided to swap output shaft and it went well(i hope) . seemed easy enough take shaft from my trans and put it in the other, well after a few clips and disks walla my shaft is switched.now i go to install trans, i line it up, i sink the bottom left and right bolt in to the engine and when i went to sink the other four bolts NOTHING, the others dont line up.
my question now is can i drive it with just two bolts screwed in? any advice would be appreciated.aloha
My camaro's headlights have stoped working! hcker2000 Electrical 4 03-04-2008 06:15 PM
just stoped by to say hi darren black Introduce Yourself 2 02-02-2006 09:35 PM
turbo 400 not working 49dream Transmission - Rearend 4 03-05-2005 07:18 PM
Walmart Stoped Flushing Auto Tranny, "I am back yahoo" Auto-Part Transmission - Rearend 2 02-22-2004 08:10 AM
speedometer stoped working 70camaro Transmission - Rearend 1 02-19-2003 01:03 AM
