My 400 sbc survived the cam break-in! - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-25-2013, 09:57 PM
SPEED MASTERS CC's Avatar
I broke in the cam with valvoline vr1 20-50w and a bottle of lucas break-in additive. I was sweating it big time! The cam is a flat tappet .575 lift 250 duration @ .05 on a 106 lsa. 11.7-1 comp. As soon as the engine fired I revved it to 3000 rpm. I fluctuated the rpm from 3000 to 2500 for 30 min. This a budget type motor. 200 cc heads, flat top claimer pistons, stock crank, eagle rods, msd ignition, dual edelbrock carbs.The more I work with the edelbrock carbs the more i like them... I ran the motor on 110 octane gas. We have about 30 guys in our car club that all use this form. Thanks for all the past help!
Old 05-25-2013, 10:01 PM
Banned
Impressed you got that lift to work out a d edelbrock carbs to run well with that duration. Which carb model? They can be tricky with larger duration cams.
Old 05-25-2013, 10:47 PM
vinniekq2's Avatar
what kind of heads? post a video
Old 05-26-2013, 06:27 AM
Richiehd's Avatar
JS-70
Who's cam?
Old 05-26-2013, 11:13 AM
camaroman7d's Avatar
You ran full spring pressure for break in? I am assuming you have dual springs.
Old 05-26-2013, 11:47 AM
The carbs are 500 cfm (each). The intake is the old edelbrock c-26 (for looks). The linkage is progressive. I did not touch the carbs! They ran great for the break-in. (The engine was run on a break-in stand.) The block is filled with hard block to the side freeze plugs. It ran cool the whole time at 180 ish. The heads are world products sportsman 2's, I know they are sub-par head today, but I had these in stock and they were professionally pocket ported. This whole motor was done on a pretty tight budget and still cost a lot... The cam is from comp. It is a custom grind. The springs are from Howards: Dual type with 135 on the seat 285 open pressure. I ran these springs with comp stainless 1.6 rockers. This is my first complete motor build I did myself. I used a chevy Z-28 oil pump and matching pan with tray from G.M. I used arp fasteners on everything. I now want to convert the carbs to run on E-85. The only carb guy that I could find that does edelbrock conversions is in Minnesota at a cost of $300 each! Ouch! I cannot find kits or info on how to do the work myself... I was told the carbs are too small for this size engine, but they are what I had purchased from another club member for a great deal. So, I ran what I had" ... I am planning on putting on 1 inch carb spacers next. I have the break-in video from a smart phone that looks great, unfortunately I am currently not smart enough to know how get the video to post here. I sent it to my email, but that is as far as I got with it...
Again thanks to the everyone on the forum, your posted info helped a bunch. Most of the guys in our club did not think the engine combo would work as well as it does. I am pretty stoked!
Old 05-26-2013, 12:25 PM
1Gary's Avatar
Last journal entry: 383 dyno sym
No synthetics for the life of the engine.A race oil like Joe Gibbs for every oil change after the break-in.We have seen lobe failures many miles later with the wrong choices.
Old 05-26-2013, 12:31 PM
vinniekq2's Avatar
post a video.The easiest way is to start a youtube acct and follow their instructions,then just post a link
Old 05-26-2013, 08:21 PM
Is Valvoline VR1 20/50 wt ok to run?
Old 05-26-2013, 08:45 PM
vinniekq2's Avatar
20/50 is a good all round viscosity.You can adjust viscosities in accordance to build clearances and severity of engines use.
The Following User Says Thank You to vinniekq2 For This Useful Post:
SPEED MASTERS CC (05-26-2013)
Old 05-28-2013, 09:33 PM
Here is the video link.
408 SBC CAM BREAK IN - YouTube
Forgot to break in cam SBC. runs okay? should i worry? caminoguy Engine 24 10-09-2011 09:21 PM
Cam break-in initial timing help on SBC v8hed Engine 2 08-25-2008 01:03 PM
Cam for 400 SBC 84KYSS Engine 3 08-19-2005 05:47 AM
400 SBC...New CAM thecamaroguy Engine 41 03-15-2005 07:47 AM
Synthetic for break in? What weight ? (engine and cam break in that is) sizemoremk Engine 5 08-14-2003 05:50 AM
