2 bolt main 400 block bore .40 over kb pistons 7cc 2 relief flat top piston skat steel crank 5.7 rods dart pro 1 200cc 72cc 2.02 1.6 alumium heads, 750 holly dp, comp cam xr 282 hydro roller cam roller lifters, roller rockers 1.6, summit stage 3 intake, th350 trans 373 gears, what do ya'll think of this set up? Estimate horse power/torque, what stall do yall think ill need im thinking 3000, this will be just driven on the streets.
high 400 depending on details, and 3k converter sounds good,not familiar with the intake?headers could be 1 5/8 or 1 3/4,depends on future use?You look like you are close to where the bigger headers are a good idea
if im using a .041 gasket where would that put my static c.r.
Related Threads
Hot Rod Forum
2.2M posts
175.6K members
Since 2001
