My '56 GMC truck has a '66 389ci.... GTO?
Hi guys,
i have just bought a 56 GMC stepside and it has a '66 389 motor in it - most likely from a GTO??. 335hp. Now this in standard for should help my truck cruise nice. But i just cant leave stuff alone ![]() Im wanting to change the cam for something a little better but will be adding a brakes booster kit and have read up that some wilder cams can cause the vaccum to be reduced - is this right? If so, can anyone reccomend a mild street cam i should use? Im not intrested in HUGE power just now but want to make it a better driver with some traffic light derby capability ![]() I will be getting headers for it and it already has an edelbrock inlet with holly carb - but not sure hwih ones just yet. cheers in advance. Andy |
X 2 with Widetrack here.
Some more info is needed. I would suspect the rear end gear is pretty low , like 3.56 or 3.73. Kinda too low for a truly streetable ride with a poncho mill as the poncho mill makes more torque and can handle higher ratios much better. Way kool that you have a GMC with a pontiac engine in it. I would love to here more about it.
Fact is stranger than Fiction |
hi huys,
many thanks for the replys. i'll get the info needed asap but might be a week or 2 as i need to get the truck picked up and brought to me so i can go over it properly to make sure she's sound & safe.It is believed that its a GTO donk, but the numbers will confirm when i get them. I do have big plans for her but as with most rodders, it wont happen over night ![]() cheers again. Andy |
1955-1959 GMC Series 100 and 500 with optional Pontiac V8 engines:
1955...287 CI Pontiac V8 engine 1956...317 CI Pontiac V8 engine 1957...347 CI Pontiac V8 engine 1958...336 CI (small bore version of Pontiac 370 CI V8 engine) 1959...336 CI (small bore version of Pontiac 389 CI V8 engine) Quick ID: If the V8 engine in your GMC truck has front motor mounts, it is the original 1955-1959 Pontiac V8. A 1960 - 1979 Pontiac V8 had side motor mounts and no provisions for front motor mounts. . |
It has side engine mounts, middle of block. from the numbers on the block its a '66 engine.
If it is truly a "GTO" engine, the heads will be "93s". 92s were on all other 389s except GTO.
The Pontiac used the timing cover for the "front mount" in those days. The aluminum versions of later years still have the bolt provosinos, but I would hesitate to use one as a "mount' in a high-torque engine. Pontiacs are very sensitive to compression versus fuel quality. Make certain your static ratio is reduced to under 9.5:1. Comp offers the XE series for the Pontiac. The XE256H is probably what you're looking for. Decent idle, good low- and mid-range power. The "next one up" (XE262H) is the most popular grind we have for "stockers". Works very well in 389s with TriPower and stock exhaust. My "dream truck" is a '59 GMC (short bed, step-side) with a 505 Pontiac in it, pulling houses down... (:- Jim |
Awesome info guys - many thanks
im such a newbie at yank stuff but i learn fast ![]() If it was a VAG or Subaru i'd be well away. lol. Im happy to have a slighty rougher idle from a cam, it sounds just awesome. I need to find some headers foe it and make up a stainless exhaust as its stock just now and is shot. I also need to look into the rear end and decide what - if needed - axle to go for. i want it to be a good driver for long distance to shows all over the UK and be able to smoke from the lights ![]() Andy |
Andy,
Let us know what you find for numbers. BTW, we "yanks" know why you Brits drink warm beer, ya know... You have Lucas refridgerators... (:- Cheers! Jim |
lol Mr P-Body
![]() The block has WW on it but no numbers can be found on the heads at all
Pat |
That is how I understood it too. LOL
Bill |
| 1962 pontiac catalina 2dr ht 389ci 2brl | gspman | Introduce Yourself | 1 | 03-26-2010 03:26 AM |
| 56 gmc truck | Kellan_723 | Engine | 2 | 06-08-2009 04:06 PM |
| 73 GMC truck | Dylanic_350 | General Rodding Tech | 0 | 02-15-2009 05:51 PM |
| 55 GMC Truck | 55GMC-Truck | Hotrodding Basics | 1 | 03-18-2008 07:01 PM |
| GTO Truck dream | Gladis | Off-Topic | 6 | 04-21-2007 09:00 PM |
