my 62 rambler - Hot Rod Forum : Hotrodders Bulletin Board
Hot Rod Forum : Hotrodders Bulletin Board > General Discussion> Hotrodders' Lounge> Introduce Yourself
Old 07-17-2008, 05:11 PM
my 62 rambler
well i go to school for auto body& paint and i own a 1962 Rambler classic it has a 5.4 l amc 327 i like to work on classic cars ..
you can view my pictures here
copy a paste
www.myspace.com/johnny547
Old 07-17-2008, 05:19 PM
my 62 rambler
Old 07-17-2008, 05:24 PM
life is a temporary assignment
Welcome aboard !!!!!!
Old 07-17-2008, 05:31 PM
Wiki Edits: 49
Welcome. Your links don't work. Try using the guided mode and the link button just above the text box to add links to pictures.
Old 07-17-2008, 05:40 PM
Wiki Edits: 31
Welcome
I have a '65 American myself
Old 07-17-2008, 07:04 PM
learn it, live it, love it
Last journal entry: better mock up pic
welcome! I just sold my 59 super wgn, to a guy that just happened to have owned it 20 yrs ago.
Old 07-18-2008, 09:03 AM
farna's Avatar
Last wiki edit: AMC V-8s Last photo:
Wiki Edits: 14
I have a 63 Classic with 4.6L (stroked 4.0L) EFI six. That 62 will be a bit of a sleeper! The 327 isn't known for good gas mileage, but has lots of low speed torque and the 62 is relatively light. One hint -- the factory Holley is only a 450-500 cfm carb. Helps on low end, but the engine will enjoy a 600 cfm better. A good low restriction exhaust will also help, 2.25" w/turbo mufflers is a good combo, but from what I see and hear on your MySpace page you might like a pair of Smitty's glass packs better, would definiitely give it a "vintage" sound! Ultimately you may want to get a better cam, as the AMC cam is very conservative. You can't just buy one, you'll need to pull yours and send it to one of the cam companies or find a good used one (287 or 327 -- both use the same cam). They can re-grind it and give you a nice boost in power. Let them know what you want out of the car and they can recommend a grind. I've had that done before. You can also mount a later model AMC aluminum intake on it. The intake requires 1/2" spacer plates on each side, but they are flat plates. The thickness allows room for some port blending as the ports are slightly different shapes. The V angles are the same for both engines, so the plates are flat. The later model has a shorter deck height, making the late intake narrower. You have to cut the water crossover from the front of the late intake, also the rear portion -- everything in front of and behind the actual intake runners. Most people use a Torker, but they mainly use it for racing. You're better off with an Air Gap or Performer for a street car.
Good luck with it!
Anybody put a Mustang II in a 58-60 Rambler American ramzoom Suspension - Brakes - Steering 29 09-01-2015 08:14 PM
4.0 HO engine/transmission combo for a Rambler Saito Engine 5 10-10-2010 02:40 PM
Anyone have info on mustang II in Early Rambler ramzoom Suspension - Brakes - Steering 2 09-23-2007 12:05 AM
Hi there Im Josh with Rudy the 62 falcon RUDY Introduce Yourself 3 01-12-2007 03:55 PM
hello, 62 rambler classic das24rules Introduce Yourself 1 05-19-2006 10:35 AM
