Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - my 671 isn't making boost?
Old 04-24-2008, 02:49 PM
68NovaSS's Avatar
68NovaSS 68NovaSS is offline
Moderator
Wiki Edits: 9
That's a cogged belt, won't slip. You sure you're not making boost at lower rpm's? Driving down the freeway at steady rpm's you're not going to be into boost anyway, as you said, boost comes in under load. If you hammer it from idle you're going to have boost if the blower is spinning! It's not an old blower with rotor to case clearances out of spec is it?
Semper Fi
