Is my 700R4 getting to OD? Cant tell. - Page 3 - Hot Rod Forum : Hotrodders Bulletin Board
  #31 (permalink)
Old 04-30-2013, 08:01 PM
Fang16's Avatar
Last journal entry: Project change
Originally Posted by RatPin View Post
I was just thinking...my truck has the original Dana 44 rear axle in it that still had the 4.11 tag attached to one of the bolts on the case. Do you think it would be possible that someone would have put 5.89 gears in it at some point and not removed the tag? The RPM's I'm seeing in what I think is 4th gear would almost exactly match where I should be if running 5.89 rear gears. Does anyone actually run those gears? When I bought the truck the original trans was blown to bits in a box in the cab, so I never drove it before now.
Anything's a possibly. Jack up the rear. mark a tire and the D/S, rotate the tire n count the turns of the D/S as the tire makes one full round. Will get u real close.
  #32 (permalink)
Old 05-01-2013, 11:08 AM
You need to verify/confirm whether or not the trans is getting 4th gear before you start looking other places.
700r4 Jethro77 Introduce Yourself 1 08-17-2010 03:30 PM
700r4 I.D. 41'srfun Transmission - Rearend 5 01-24-2009 07:34 PM
700r4 no d or od pondriver Transmission - Rearend 4 10-12-2007 09:16 PM
Removing a 2.8/700r4, Install V-8 with 700r4 1230firebird Transmission - Rearend 4 09-17-2007 05:17 PM
What are the parts in a 700R4 2-3 TransGo shift kit 700R4 2-3 AngliaBob Transmission - Rearend 3 04-23-2005 11:25 PM
