Interesting name....im building a wicked 73 nova...its the same as a 74. If you want some pointers let me know. The car is definately worth building and there is a huge aftermarket for all novas up to 74. Did you check your spark plugs? could one be fouled? I have a 70 chevelle that the motor blows so much oil that it will foul out a plug but run just good enough to drive. Check your ignition stuff first. If its not that your carb may need a good rebuild. What do you plan on doing with the car? Drag? Street? Let me know
