My 83 truck all of the sudden will not idle - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-18-2012, 11:23 AM
I have an 83 GMC with a SBC 355, 600 edelbrock carb, and cheapo electronic fuel pump from advanced. Fire her up one day and it idles and runs like a champ. Then I start it the next day and now it will not idle. I thought the idle circuit may be clogged so I switch it out to another 600 edelbrock... still no idle. I shut it off and start it again and it idled perfect... until I started driving. I pulled the fuel line off the carb and put it in a 20 ounce bottle. It filled it in 7-10 seconds.
Any ideas?
Old 03-18-2012, 01:57 PM
Did you check for loose or rotted vacuum lines?
Have you recentlly filled the gas tank?
Did you check to see if timing is correct?
Old 03-18-2012, 03:21 PM
I took the filter off and blew it out. I didnt feel any resistance but its running fine now..
All of a sudden 350 sbc won't idle toddiyaayas Engine 3 10-31-2011 06:43 AM
Idle control, Dodge truck oldred General Rodding Tech 15 09-09-2011 09:43 PM
Truck won't idle...Need Help mudbog42 Engine 14 03-01-2008 03:16 PM
Sudden High Idle......HELP!!!! gpeak Engine 17 08-26-2004 03:46 AM
350 sudden rough low idle JohnnyGTO Engine 9 06-19-2004 06:52 PM
