Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - My Air Compressor is SPRAYING OIL! Help!
Old 08-13-2009, 03:23 PM
oldred oldred is offline
I assume from the way you describe the problem in your last post that it quits spraying after the pump stops? If so that eliminates a stuck back-flow valve but it still sounds as if you have air pressure leaking into the crankcase, does it have air coming out with the oil? Make sure the crankcase is not overfilled and if not you need to determine how the pressure is leaking into the pump case.
