My AirBag light is on and no air coming out of vents - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-03-2011, 01:01 PM
Hey guys,
I have a 2004 Dodge Neon SE that I just bought and the airbag light is on and there is no air that comes out of the vents when you turn on heat or A/C and the defroster doesnt turn on. The horn still works but I've heard this can be related to a bad ground or something but not to sure. I'd hate to replace the clockspring or something if its just a wire you know.
Old 08-03-2011, 07:53 PM
LATECH's Avatar
You have 2 seperate issue, the first one SRS lite (airbag) could be the clockspring,they can fail on the power side as well as the ground side,if the ground fails the horn wont work ,and the airbag light will light.If the airbag power side goes open the horn will work but the airbag light will illuminate.
Did you retrieve a code for the driver side deployment loop open circuit?
The air flow issue....does air come out the defrosters? Do you hear the HVAC fan running? More info needed to help here.
Old 08-03-2011, 08:20 PM
I hooked up a code reader and it came back, system voltage low. Not sure if that means anything. There is no air that comes out the defroster. when i turn it on i dont hear or feel anything.
What do you mean by airbag power side goes open?
Old 08-04-2011, 07:32 AM
Wiki Edits: 27
used car ?
some used car mechanics are known to send cars out with an inop or defective air bags, get them sold the cheapest patch job possible.
Airbag Light ziggarot Electrical 2 03-21-2011 07:26 PM
No Air coming out of defrost only front vents 350chevypower General Rodding Tech 23 08-30-2010 09:28 PM
Blazer airbag light. BToops396 Electrical 2 02-11-2010 08:38 PM
sensor light keeps coming on wiseguy50 Engine 6 01-14-2006 07:21 PM
generater light is coming on 1cool62 Electrical 4 01-05-2003 07:01 PM
