My alternator is magnetic?!? - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-27-2011, 01:52 PM
Just swapped old 350 motor for new one in '50 Ford truck. Now some gauges don't work properly. Temp gauge pegs to right and gas gauge to left when ignition on...also block & alternator become magnetic. Both the frame and chassis are grounded to the negative battery post, and the block is grounded to the frame with battery gauge cable. Any suggestions are encouraged. Thx.
Old 12-27-2011, 02:02 PM
poncho62's Avatar
Wiki Edits: 5
The alternator will be magnetic with the engine running.
Your gauges are made to run on 6 volts not 12, you need to wire them through a drop resister
Old 12-27-2011, 02:17 PM
BOBCRMAN@aol.com's Avatar
Your gauges are also positive ground..
Old 12-27-2011, 02:18 PM
Thx for reply. They are 12 volt gauges.
Old 12-27-2011, 03:19 PM
JeffB's Avatar
Add another ground strap from an intake bolt to the firewall.Try swapping the terminals on the gauges and see if that helps,sometimes to get a good ground for the gauges you may have to make the metal underneath the ground wire bare and use a star washer.Had the same problem with a gas gauge and added an additional ground wire to the sender and it fixed it.
Old 12-27-2011, 10:05 PM
matts37chev's Avatar
& matts38chev
Last journal entry: Try again
gauges pegging, sounds like a bad sending unit (or grounding out)
did you swap out the sending units from the old engine?
Old 12-28-2011, 10:43 AM
What gauge are in the truck,stock fords had some kind of voltage limiter to limit voltage to the gauges.
HEI magnetic pickup 70bird Engine 0 08-29-2009 05:45 PM
Magnetic Flex Rulers Ricoch3T Garage - Tools 3 02-27-2008 03:31 PM
Magnetic Pick-up Gap - Duraspark nova69 Electrical 6 03-07-2006 04:31 PM
magnetic filtration JIM BAR Engine 3 02-01-2006 11:27 AM
Magnetic clutch release bird Electrical 2 08-29-2004 02:11 PM
