Is my alternator overcharging? - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-27-2011, 02:55 PM
Last journal entry: Con't
Just got my rod on the road today for the first time. Seems to run good and I'm watching the gauges like a hawk. All seems well except my volt meter reads 15 - maybe a little more. I put a volt meter across the battery terminals while running and it reads about 14.3 - 14.5. Which do I believe or is there more testing to be done. Its a 351w with a new 3 wire GM alternator and VDO gauges.
Old 04-27-2011, 03:05 PM
eloc431962's Avatar
Evil Wicked Mean And Nasty
Wiki Edits: 37
definitly showing overcharge, i could handle the 14.3 of course it's should be reading from 13.8 to 14.5 but above that Do you have another gauge around to try and have you had the battery load tested also, but it is showing overcharge though i can understand your concern. What gauge wire did you use hooking this up ?
Cole
Old 04-27-2011, 03:18 PM
I dont have another gauge, the battery is new but I do have a load tester if thats what I should do. Dont recall wire gauges off the top of my head but I followed Marks (from MAD electrical) plan and tried to be fussy with grounds. By the way battery is in trunk. RPM's dont seem to make a difference but I think the gauge may have read a touch higher after I drove a while. My tester is not digital, maybe I need a better tester. Also I wasnt sure how to test the alternator. No radio, AC, or lights etc. on. Thank you.
Old 04-27-2011, 03:27 PM
eloc431962's Avatar
Wiki Edits: 37
Do you remember what gauge wire you ran to the battery ?
Cole
Old 04-27-2011, 03:37 PM
charge rates
throw another meter across battery terminals, 14.5 is fine. most dash units are not always that accurate.
Old 04-27-2011, 03:41 PM
eloc431962's Avatar
Wiki Edits: 37
X2 i would re-check across the battery before i got to into it, I have seen to many new gauges be bad in the past. IMHO
As i stated it should be 13.8 to 14.5.
Cole
Old 04-27-2011, 04:31 PM
T-bucket23's Avatar
Wiki Edits: 26
It is not unusual for the voltage to go up after the battery is charged. You need to get a reliable meter and check the voltage at the battery terminals and at the alternator. The readings should be very close to the same, if there is more than a .2 -.3 difference you either have a bad connection or an under sized wire in the charging circuit.
Chet
Old 04-28-2011, 08:15 AM
I checked things again this AM. The dash gauge reads about 14 this morning. I got 14 at the battery and about 13.8 with high beams on.The alternator was a little less(?) - about 13.3. I'm gonna drive it some more and see if it creeps up. Wire gauge from alternator back to battery is "8". I'll also see if I can bum a better meter and recheck, but at the moment I feel better. Thank you everyone
alternator is overcharging - need advice what to do pigjamelectric Electrical 4 12-02-2010 02:51 PM
Powermaster 140A Overcharging 68NovaSS Electrical 8 10-08-2007 09:53 PM
Am I overcharging?? cutsupreme Electrical 4 06-16-2007 05:38 AM
altinator overcharging walkn slow Electrical 2 03-20-2007 10:09 AM
chevy alternator overcharging at higher rpm tim2 Electrical 3 11-02-2003 10:28 AM
