My baby needs help - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-29-2008, 07:45 PM
oldguy829's Avatar
Last wiki edit: Swapping to rack and pinion steering
Last journal entry: 53 coupe
Wiki Edits: 88
My baby needs help
Not my hotrod, my baby. she's going to school in Lubbock Tx, 400 miles from here and is having car trouble. It's been going on for months. Sometimes, when she stops for a light, it doesn't want to accelerate. Won't go over 2000 RPM's. Took it to the dealer, nothings wrong. She was home in August and I drove it several times, no problem. Then one day it did it. Took it to the dealer. Nothings wrong. Next week it did it again, I took it back and told them to keep it over night and drive it several times. Never did it for them, but they did a tune up. Wires, cap, rotor and plugs. Also ran cleaner through it. Fine for 6 weeks, now it's acting up again. One time as she was accelerating to get on the freeway, said it got to about 3,000 rpms. Usually she can let up on the gas and try again and it will go. Couple of times she pulled over and turned it off, and restarted and it was OK. Never loses power once she is up to speed, it's always on acceleration. It's a 2006 PT Cruiser, now out of warranty of course. Any Ideas? Or a good, honest mechanic in Lubbock? The dealer is worthless. Charges $79.00 to tell her it's fine.
Old 09-29-2008, 08:02 PM
406 bug's Avatar
9.82 @ 139mph
Did the dealer check the fuel delevery system ?
Old 09-29-2008, 08:08 PM
oldguy829's Avatar
Wiki Edits: 88
baby needs help
Good question. Lets assume they didn't do squat. Are you thinking fuel pump pressure, or injector pump? Forgot to mention, the check engine light sometimes comes on during these episodes, but goes back out and doesn't leave a code?
Old 09-29-2008, 08:27 PM
406 bug's Avatar
9.82 @ 139mph
yes, lots to consider - pressure regulator ? pump? filter. I would assume (but thats just me ) that the dealer would have checked for stored code?? . Problems that are intermittent are difficult. Sometimes you have to do what some repair shops do -- just start replacing stuff until its fixed.
Wiki Edits: 31
I have a friend with a '01 Neon ( same as PT Cruiser except body panels ) with the smaller ( 2.0l? ) 4cyl and auto. does pretty much the same thing, fairly frequent.. she's just looking for a new car instead of fixing it ( it is still drivable like it is ).. I always suspected the fuel pump myself, in the earlier Neons they were a problem, but I'm not sure on the newer 1's...
just as an FYI. if the check engine light comes on, in a chrysler, the computer will save the code as pending and freeze frame the data for a set amount of miles ( 300 usually ). chances are, they are not plugging the car into there scanner, otherwise they would know something is up and exactly what conditions it happened under.
Old 09-30-2008, 09:44 AM
oldguy829's Avatar
Wiki Edits: 88
baby needs help
Thanks for the opinions guys. The 300 mile limit on the stored code would explain that. She drove home (400 Miles) before we took it in. Letting the dealer throw parts at it can get real expensive.
Can anyone recommend a shop in Lubbock?
Old 09-30-2008, 09:55 AM
6426yy's Avatar
I understand your frustration, our old car an Olds Alero kept throwing the security light and would not start. Let it sit for 10/20 minutes and it would be fine. Local mom and pops charged $400 and didn't fix it advised us to use the dealer, another $400 still didn't fix it back to dealer again still no fix. So we just traded the damn thing off and let some one else deal with it. I think our dealership is just a glorified Wal-Mart lube shop.
Hope you figure it out, let us know the problem.
Baby Shoes from Rear view mirror rwruther Hotrodders' Lounge 19 07-17-2008 10:05 PM
Baby Names Malibucdl Off-Topic 5 10-31-2005 01:00 AM
We had a baby...it's a boy!!! mustangbaby Hotrodders' Lounge 20 11-04-2003 07:37 AM
Signed, sealed, delivered, it's yours! Madd Syntst Hotrodders' Lounge 10 09-29-2003 12:50 PM
