My BBC build. - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-04-2012, 04:57 PM
My BBC build.
I have been dragging this out for some time an it is finally starting to come together. Thought I would share some pictures. Should be able to start on it
again some this weekend.
Old 04-04-2012, 06:00 PM
starnest's Avatar
elkyholic
Last journal entry: Center Link Installed
What pistons are you using?
Old 04-04-2012, 06:39 PM
Those are some TRW's I have that have never been used before. You are suppose to be able to run them either way CC or OC. Should be around 10.8. I check the piston to valve clearance after I put the first piston in an everything was good.
Old 04-04-2012, 06:41 PM
zildjian4life218's Avatar
Listen and Learn
Last wiki edit: DIY junkyard electrical fan controller
Last journal entry: SBC 305 Twin Turbo
Wiki Edits: 7
Looks good! Keep posting pics.
Old 04-04-2012, 06:46 PM
I have a lot of irons in the fire ,it is slow go. I already have parts bought. I try to work on it when I do not have any distractions.
Thanks for the compliments.
Old 04-04-2012, 06:48 PM
BOBCRMAN@aol.com's Avatar
Looks great. I don't know what heads you are using. Remember. You can't use that dome with GM oval port OC or CC heads.
Old 04-04-2012, 06:51 PM
Listen and Learn
Wiki Edits: 7
Okay I seriously have never heard the terms OC or CC used before any chance closed chamber open chamber?... can anyone explain this to me? lol thanks.
Old 04-04-2012, 06:55 PM
Tell me more on using GM ovals heads with these pistons. I am not using GM heads.
Old 04-04-2012, 06:57 PM
Yep you hit the nail on the head.
Old 04-04-2012, 06:58 PM
Listen and Learn
Wiki Edits: 7
Lol sorry for the stupid question but I never heard it worded like that before. But thanks!
Old 04-04-2012, 06:59 PM
CC- Closed chamber heads, have a tight bathtub style combustion chamber. OC- Open chamber, have the chamber spark plug side laid over like half of a hemisphere. Makes for better emission and also breathes better. Better flame travel. 65-70 oval port heads CC. 71 and later, most are OC.
Old 04-04-2012, 07:07 PM
OK. The TRW pistons you have were designed to be used with rectangle port closed chamberGM heads
These heads are not the same in the combustion
chamber as the oval port. Tho, to the casual glance they look alike. The rectangle port heads use a chamber that is releived more around the perimiter. Making the chamber just a bit larger across the distance of the valve faces. The oval port head will hit the pistons on the exhaust side at the deck and outer edge of the dome.
Old 04-05-2012, 08:43 AM
Nice..I have a never used set of Merlin VR 345cc heads that would look good on that..All Manely valves,springs ect..Pocket ported by Bud Harper.One problem..Iím in Afghanistan! Be lookin to sell soon though.Be great on a 496.
Old 04-05-2012, 09:50 AM
1971BB427's Avatar
What? I'm using TRW forged domed pistons with oval port, closed chamber heads in the 427 in my '71 Camaro. They've been in there for 13 yrs. now, and no clearance issues.
Is there something about these particular domed pistons the OP is using that is obvious that I can't see looking at them? They appear to be the same thing I've got in my engine.
Old 04-05-2012, 11:39 AM
starnest's Avatar
elkyholic
I have the KB (25CC) domed pistons with 820 heads (the heads have the larger (rect port) valves w/machining to unshroud). When I assembled, the outer edge of the dome did hit inside the chamber (not the deck); which I clearanced with quite some effort. (I worked until they cleared w/o head gasket - this gives me plenty of clearance when installed with regular .041 compressed gaskets).
Bowtie - with 10.8 DCR, you will have big problems running pump gas.
New BBC 454 build chevykid90 Engine 48 07-22-2011 08:26 AM
489 BBC build hotrodmy55 Engine 6 03-27-2011 02:59 AM
My first BBC build. Help wanted. my_wayward_son Engine 11 06-15-2010 02:23 PM
Bbc Build Up thefloyd1973 Engine 14 07-09-2009 08:09 PM
Critique my BBC build please trunty Hotrodding Basics 3 02-05-2009 04:32 PM
