My blown BBC has glowing red hedders - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 02-01-2012, 11:56 AM
Originally Posted by crazypj
Red hot headers seems pretty normal to me, zero airflow as it's not moving and takes about 30 sec.
Your using tube exhaust manifolds which are pretty thin, normal exhaust gas temps are in the 1,000~1,400 deg range which is plenty to make them glow.
What diameter pipes are you using?
They could be a restriction as your moving a LOT of gas through them.
You really need to get it on a dyno with multi gas analyser, it will be much cheaper than a re-build
Ok to.anwser this ? Headders.are.headmans yes pretty thin.2inch primarys with collector.cut.off.to.3.5 inches into.the.same.dia. Dyno max.see. Though muffs.
Im going to to fire up my other.streetrod.and see if they glow.same brand headder but 409w.in.83.gt mustang runnint.11.26 &10.09.on 200 shot
  #17 (permalink)
Old 02-01-2012, 05:50 PM
68NovaSS's Avatar
Moderator
Wiki Edits: 9
Can you stop having periods appear after every word or two in your posts? Along with your run on sentences, it makes your posts very difficult to read. I'm not throwing the grammar card, only trying to make it easier for others to provide help.
Semper Fi
  #18 (permalink)
Old 02-01-2012, 06:35 PM
matts37chev's Avatar
& matts38chev
Last journal entry: Try again
I noticed this in his early post
posting by phone?
mine does that (random periods) you really gotta pay attention
then its a pain to get rid of them
  #19 (permalink)
Old 02-01-2012, 06:39 PM
T-bucket23's Avatar
Wiki Edits: 26
Even N/A engines will make tubular headers glow red if you hold at 2~3,000 rpm, which part of hot exhaust gas didn't you understand?
Steel starts coloring around 900 degrees f, if the wrong cam is fitted and valve is opening while combustion is taking place the pipes will glow real quick even if timing and A/F ratio's are perfect stainless steel or titanium pipes are often made of thinner gauge material and glow real quick at any rpm above idle
If he was using cast manifolds I would say there is a major issue
As it stands, it's more a 'fine tuning' thing and I think a trip to dyno will be quickest /cheapest solution
Your tagline under your name fits you perfectly
Chet
  #20 (permalink)
Old 02-01-2012, 08:04 PM
glowing header is fuel burning inside the header.
surge at idle means lean.
low timing at idle makes you turn up the idle screws which opens the throttle blades past the transfer slots which makes the mixture very rich.
when you advance the timing, the idle goes up and you turn down the idle speed which places the throttle blades in the correct postion, but it is leaner.
30 degrees at idle (locked) and richen up the idle mixture screws sounds like the cure to me.
  #21 (permalink)
Old 02-01-2012, 08:18 PM
bigblockragtop's Avatar
I and others had suggested this. I think his fear is too much timing and detonation. The cure would be a boost retard or locked timing like you said. The locked timing makes for hard starts but a boost retard ignition box has a start retard also.
  #22 (permalink)
Old 02-01-2012, 10:36 PM
68NovaSS's Avatar
Moderator
Wiki Edits: 9
Surge, or blower roll, isn't necessarily a product of a lean motor, especially in a roots blown motor. I have blower roll and I'm rich at idle, the leaner I tune it the tamer it gets.
Semper Fi
  #23 (permalink)
Old 02-02-2012, 03:43 AM
[QUOTE=bigblockragtop]I and others had suggested this. I think his fear is too much timing and detonation. The cure would be a boost retard or locked timing like you said. The locked timing makes for hard starts but a boost retard ignition box has a start retard also.[QUOTE]
A msd .Digtal.6.aould.take.care.of.the.cranking.cause.ot .retards.10°on.start.upplis.has.moe.feature
please.be.kind.my cell space.bar.to to colse.the.the.peroid.burrom.plis.i ogt.big thumbs.i.sid.not.ser.rhisphome.up to my touch that could be.rhe.problem.but yes.i can.say i.do have run.sentcences.but.hey i dropped.up in9rh.grade.but most.be.doong.somerhing right if.i got.7.cars.total
how.yoy lkke.thay.rhYs whay happens when i type fasr..i trt.as.besr.i can.sllwso gibe.i poor.boy.a.break.only got half.a.brain.of.you.know.what i mean
  #24 (permalink)
Old 02-02-2012, 06:34 AM
Last journal entry: Finally some floor!
[QUOTE=2fox][QUOTE=bigblockragtop]I and others had suggested this. I think his fear is too much timing and detonation. The cure would be a boost retard or locked timing like you said. The locked timing makes for hard starts but a boost retard ignition box has a start retard also.
WOWZA! SCARY!!!!!
  #25 (permalink)
Old 02-02-2012, 07:14 AM
[QUOTE=StreetKruzer][QUOTE=2fox]
Originally Posted by bigblockragtop
I and others had suggested this. I think his fear is too much timing and detonation. The cure would be a boost retard or locked timing like you said. The locked timing makes for hard starts but a boost retard ignition box has a start retard also. WOWZA! SCARY!!!!!
Did you like that.fast.typing ?.i thought.not so get what you can get out of it.of not.just dont post here.anymore
but everyone else.thanks for.all the.advise
  #26 (permalink)
Old 02-02-2012, 08:38 AM
X2 and i think you are rich off idle.i tuned my carbs with blocked pv,s and use a LC-1 a/f meter.
http://i1180.photobucket.com/albums/...1/100_4126.jpg
  #27 (permalink)
Old 02-02-2012, 08:48 AM
Banned
Glowing headers is usually from not enough ignition advance or too lean of fuel mixture. It could be something else but I would start there. It sounds like your fuel curve is really fubared, rich in some spots, lean in others. A few more degress of timing will help but I doubt its the cause of this problem. You need to boost reference your carbs as stated.
  #28 (permalink)
Old 02-02-2012, 08:50 AM
I been watxhing you.tube videos of.red glowing headders.even an indy car
  #29 (permalink)
Old 02-02-2012, 08:58 AM
ok now your just scaring me
  #30 (permalink)
Old 02-02-2012, 08:59 AM
if you watch a video of a blower engine on the dyno the headers will NOT glow red.
need help finding hedders zenchal26 Engine 4 09-28-2011 06:17 PM
Hedman Elite hedders boss350 Engine 2 02-16-2007 01:03 PM
tri-y hedders for a hot 482 BBC dykkerdan Engine 9 12-22-2005 02:27 AM
66 Stang w/ 302 Hedders?!?!?! slavboy1 Engine 0 06-29-2004 08:16 PM
who makes hedders PropanePower Hotrodding Basics 7 04-01-2004 09:17 AM
