My blown BBC has glowing red hedders - Page 3 - Hot Rod Forum : Hotrodders Bulletin Board
  #31 (permalink)
Old 02-02-2012, 08:59 AM
if you watch a video of a blower engine on the dyno the headers will NOT glow red.
  #32 (permalink)
Old 02-02-2012, 09:01 AM
here is mine to watch.
http://www.youtube.com/watch?v=deuuTcazgrU
  #33 (permalink)
Old 02-02-2012, 09:18 AM
Last journal entry: 66 Nova SS
My Blown BBC has red hot headers.
I would have to agree with Chet and some of the other gentlemen, Time seems the cause for backfire and red glowing is a fuel issue, I would put my self out and say to lean or to rich. do vacum test and run 16 PSI, get number one TDC rotate to intake and make sure they are TDC. With dual 4's adjustment is critical as well as linkage set up. If you have a local tuner or shop that dyno tunes its worth the extra $$ to get this perfect and they will find extra HP also. its like $125.00 per hour around here, but well worth they money. Hope you post what you found to be the problem, very interested in the results.
  #34 (permalink)
Old 02-02-2012, 09:46 AM
T-bucket23's Avatar
Wiki Edits: 26
Originally Posted by 2fox
I been watxhing you.tube videos of.red glowing headders.even an indy car
Yup and they are running on the edge and get rebuilt after every race. Are you willing to rebuild your engine every couple hundred miles. Dragsters also glow the exhaust and the engines are good for 4 seconds before requiring a rebuild.
Chet
  #35 (permalink)
Old 02-02-2012, 10:38 AM
F-BIRD'88's Avatar
Yada Yada Yada
Any hot hard start issue resulting from locked out distributor advance is easily dealt with by using a simple spark power interupt switch to kill the spark during initial starter cranking.
Crank it over with the switch off and hit the switch once it get cranking and it will fire immediately.
Blower motors need lots and lots of initial timing at idle.
Make sure the rear starter support bracket brace is installed on your GM starter motor. Its a required OEM $10 part.
As far as watching glowing headers on dyno motors that have nothing to do with your motor or glowing headers at idle or 3000 rpm part throttle, you seem hell bent on being a fool.
Glowing headers is fuel burning late in the exhaust system.
(not enough spark advance,lean fuel air mix, over rich fuel air mix, spark misfire, incomplete late combustion))
Nitromethane burns so slow it never gets all burned in the chamber , thats why the nitro fueled blower motor's headers glow.
Exhaust valve and seat life is very low.
Fix the timing and the carbs before you melt this motor.
You may have a vacuum leak at a gasket joint.
If you don;t get it, get a pro to help you tune it.
  #36 (permalink)
Old 02-02-2012, 02:15 PM
Last journal entry: Finally some floor!
[QUOTE=2fox][QUOTE=StreetKruzer]
Did you like that.fast.typing ?.i thought.not so get what you can get out of it.of not.just dont post here.anymore
but everyone else.thanks for.all the.advise
You misunderstand: I'm not amazed at your posting skills, what I'm surprised at is being fairly adamant about bucking a lot of suggestions in the same direction. I don't know about you, but I couldn't risk my blown big block build without checking/doing some of these suggestions before having a real BLOWN BIG BLOCK BUILD!!!!!!!!!
  #37 (permalink)
Old 02-02-2012, 07:55 PM
[QUOTE=StreetKruzer][QUOTE=2fox]
Originally Posted by bigblockragtop
I and others had suggested this. I think his fear is too much timing and detonation. The cure would be a boost retard or locked timing like you said. The locked timing makes for hard starts but a boost retard ignition box has a start retard also. WOWZA! SCARY!!!!!
  #38 (permalink)
Old 02-02-2012, 08:12 PM
bigblockragtop's Avatar
I am totally confused, I did not comment on your grammar, is this somehow at stab at me? Is this thread about glowing headers? I am no Steve Morris or Jack Merkel I just try to help a fellow hotrodder if I can. I did not go to school or work my whole life as a mechanic but this thread is way out of hand. If you are trying to insult me that's fine I have big shoulders I can handle it. Don't listen to anyone, toast marshmallows on your headers or just stand around on a cold night with some friends and beer and keep warm. My children told me long ago don't let the internet trolls bother you. Good luck to you have fun with your glowwy headers
  #39 (permalink)
Old 02-03-2012, 04:52 PM
Last journal entry: My Last Hot Rod
Our stock car had the samw
It was ignition timing, it was way to much advance..
  #40 (permalink)
Old 03-08-2012, 07:57 PM
Manguys I got at last...no red hedders go to blower roll post .I posted there.click my name.to find all post read last.entry. yahoo
  #41 (permalink)
Old 03-08-2012, 09:10 PM
Originally Posted by 68NovaSS
Surge, or blower roll, isn't necessarily a product of a lean motor, especially in a roots blown motor. I have blower roll and I'm rich at idle, the leaner I tune it the tamer it gets.
You are so very correct I got it tamed.
  #42 (permalink)
Old 03-08-2012, 09:14 PM
ok now your just scaring me
Hey man sorry that was.not.meant for you you didn't dog me.plaese.accept my deepest regrets I think I got it at last BTW not used to this new small. Ell phone with spell.check it sometimes puts.words.really. out of wack.as you my all know
need help finding hedders zenchal26 Engine 4 09-28-2011 06:17 PM
Hedman Elite hedders boss350 Engine 2 02-16-2007 01:03 PM
tri-y hedders for a hot 482 BBC dykkerdan Engine 9 12-22-2005 02:27 AM
66 Stang w/ 302 Hedders?!?!?! slavboy1 Engine 0 06-29-2004 08:16 PM
who makes hedders PropanePower Hotrodding Basics 7 04-01-2004 09:17 AM
