My buddy is moving... - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-21-2005, 05:51 PM
schnitz's Avatar
Last wiki edit: Building a new shop
Last journal entry: Christmas 2008 came early!!!
Wiki Edits: 54
And, he's giving me some of his extra parts. So far, I've gotten an old Chevy intake (it has the fill tube in the intake--late 60's I believe) almost a dozen valve covers (including the aluminum M/T tall ones at the top of the stack), a couple of oil pans full of old engine internals, a steering column from a late '80s Camaro, and just a box of assorted goodies. It sucks that he's moving, but it looks like Christmas is early at my place. I'll post more pics as I find more goodies. There's also, I guess, going to be a couple of 4.3 engines, a small pile of transmissions, and an engine stand. He's only moving about an hour away, but the new place is a lot smaller, so his loss is now my gain. I suppose it pays to be in the right place at the right time. The sad part is, we worked on a lot of stuff together, and I will lose a good teacher. Oh well....
In a while, Chet.
Name:	Old Chevy intake.JPG
ID:	7943   Click image for larger version
ID:	7944   Click image for larger version
Name:	Some stuff.JPG
Old 11-21-2005, 07:14 PM
78novaman's Avatar
The AMC, FORD, & CHEVY Guy??!!
Last wiki edit: Improving fuel economy
Last journal entry: Finally on the road
Nice grab
Those M/T valve covers would look great on my nova
Old 11-21-2005, 08:24 PM
schnitz's Avatar
Wiki Edits: 54
i figure that they'll look even better on my Monte. As soon as I figure out the best way to get them clean, anyway...
I've now found a few S-10 blazer parts, and an aluminum brake master cylinder. Too bad there's no booster to go with it. Does anybody need a Ski-doo tach?
In a while, Chet.
Old 11-21-2005, 09:03 PM
killerformula's Avatar
Last wiki edit: Carburetor
Last journal entry: Clean up
Wiki Edits: 3
Originally Posted by 78novaman
Nice grab
you'll need to hammer the crap out of them to get them to fit on the inline 6, but i've made tighter fits work before!
K
Old 11-21-2005, 09:30 PM
sicksixseven's Avatar
Ground Clearance Is Over-Rated
Hey Schnitz, if you wernt out in wisconsin, I could definately make a little room in my garage for 4.3. My Toyota 4runner has been craving one for a while now
Sam
Old 11-22-2005, 07:57 AM
Beenaway2long's Avatar
or Jeff, or Doc, or...
Last journal entry: Results of the Camaro
send the valve covers to Ron (RCastle), for a quick polishing.......
How long is that steering column??
Old 11-22-2005, 09:20 AM
WakBordr7387's Avatar
Gone fishin'
Last wiki edit: Removing stuck fasteners
Last journal entry: blah.......again
Wiki Edits: 2
Nice find dude, Those valve covers look like they would look almost brandnew with a little polishing.
Do you have a pic for that seadoo tach? I gotta a couple seadoos siting in my backyard, I might be able to use it.
Brad
Old 11-22-2005, 07:18 PM
schnitz's Avatar
Wiki Edits: 54
I may have to send them down, I'm not sure how to get them totally clean.
How do you want the measurement? From the middle of the wheel to the end of the splines, or what?
Brad
Yeah, I can get a pic in a day or two, but it's a Ski-doo, not a seadoo. I'm not sure it'll work for you, but I hope it will. Been busy helping with the move. Lots of boxes. And now I inherited a Jacobson snowblower and a garden tiller. I didn't even know that he had either of them. And, I don't even know if they run...
In a while, Chet.
Old 11-22-2005, 07:38 PM
Sand blast them. It will not hurt the aluminum. 78novaman you want a set. let me know I have a set in the shop. Someone has made the pcv holes for the larger size I beleive and they do not have any baffles. I picked them up cause they were cheap and not really sure if I will ever use them or not.
Old 11-22-2005, 07:43 PM
schnitz's Avatar
Wiki Edits: 54
Thanks, I never thought of sandblasting them. That'll work great to clean up the insides, too.
In a while, Chet.
Old 11-23-2005, 07:11 AM
bead blast the aluminum. less agressive.
From back of wheel to column end , where splines come out of. (plastic bushing)
Oops, nevermind. I didn't see that it has a shifter on it. I need a column that doesn't have a shifter.
Jeff
Old 11-25-2005, 10:47 AM
A good silica sand will not hurt the aluminum at all. I have done this many times with aluminum parts without any pitting at all.
Old 11-25-2005, 02:17 PM
schnitz's Avatar
Wiki Edits: 54
Opps Brad... It's a Bombardier
Sorry about that. It says Bombardier on it, not Ski-doo. But here's the pics anyway.
In a while, Chet.
Name:	Tach front.JPG
ID:	7998   Click image for larger version
Name:	tach side back.JPG
Old 11-26-2005, 08:39 AM
Gone fishin'
Wiki Edits: 2
Thanks chet, Both of mine are bombadiers. Neither of them have a tach, of and I didn't see any type harness that they might go into.
Ill look into see what it takes to wire one of them up. I could use it since were considering turning one into a hotrod by building the engine out of the 3seater and swaping it into the 2 seater.
Brad
is this about right or is my buddy getting hosed?? jesse01 Hotrodders' Lounge 21 11-20-2005 06:01 PM
is any one elses site moving slow? rat_guerue Hotrodders' Lounge 24 10-01-2004 10:34 AM
cruel things you've done to people..... akm Hotrodders' Lounge 70 07-07-2004 07:35 PM
Buddy was boned- No I need info ! Beenaway2long Hotrodders' Lounge 4 04-15-2004 11:33 AM
moving the gas tank!! slider in wa General Rodding Tech 9 08-27-2002 12:08 PM
