My build
1977 454 CHEVY .030 over KB 203 pistons with a .133 dome , new scat 6.135 rods, stock crank turned .010 and .010, bock decked .005, edelbrock rpm air gap, hooker comp headers, weiand long water pump. No heads or cam yet, want some ideas,want to use aluminum heads and roller cam. Thinking brodix race rite heads and cam and lifters from comp cams.
454 build
The Brodix RR have 119 cc chambers. With your pistons that will give you around 9.01 compression. That's a little on the low side for aluminum heads. Comp recommends 11-700-8,XR274R in a solid roller. Rpm range is 2200-6200. Also needs 2500 stall converter. The other cam 11-771-8,XR280R recommends 2800 stall, 10.1 or more compression, and 3.73 to 3.90 rear gears. KB 207 would have given you 10.2 compression. I like Brodix heads too.
Brodix also has the racerites in a 115 cc so that might help a bit.
My build
Thanks for the info. Want to go with a hyd roller, running a 4 speed, and dont know what gear i have out back.
| 355 build??'s about compression and build | impalaman355 | Engine | 6 | 06-06-2011 10:20 AM |
| USA BUILD vs CANADIAN BUILD? | troy norrad | Hotrodding Basics | 19 | 02-18-2008 09:57 PM |
| 200-4r experts - build questions - Which core is best to build on? | Warrant | Transmission - Rearend | 7 | 10-09-2007 07:36 PM |
| Please help me build this: | Mikeeal | Engine | 19 | 08-28-2007 07:53 PM |
| Help on new build. | bnutty | Introduce Yourself | 2 | 04-25-2006 06:16 PM |
