My Build-up (suggestions, help) - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-21-2003, 09:05 AM
- 350ci 4 Bolt
- Camel hump heads 2.02/1.60 (Some port work)
- Edelbrock Air Gap (Matched to match heads)
- Headman headers 1 5/8"
- Holly 650 Carb
- Comp Cam Magnum 280 (.480/.480) OR 286 (.490/.490)?
- Comp Magnum 1.6 ratio roller tip rockers
- Some new springs (what kind?)
- Some new rods (what kind?)
- Some sort of flat top pistons? (what kind?)
Help me make my plans better and more indepth. I wanna have a set out plan and buying order so that when I get more money I can start buying some of this stuff.
b]Please Visit My Site[/b]
<a href="
target="_blank">http://www.geocities.com/montecarloss_01/Monte.html</a>
Old 06-21-2003, 04:04 PM
<a href="
Old 06-21-2003, 04:44 PM
302 Z28's Avatar
Sounds like a good start. I would go with some forged flat top pistons, and GM's PM rods.
Vince
Old 06-22-2003, 09:24 AM
Ok thanks, any other suggestions?
<a href="
Old 06-22-2003, 09:52 AM
TurboS10's Avatar
Last wiki edit: Auto Terms and Definitions Used in Modern Engine T... Last photo:
Wiki Edits: 2
Keith Black Hypereutectic Pistons and Scat 5140 Rods with a Scat Cast crank. Get the springs to match the cam you have picked. The manufacturor will have a recommended set.
Chris
