my cadillac brake light - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-29-2008, 08:23 PM
this is not a hot rod question but my daily driver 1994 cadillace deville right brake light dont work when the lights on. it shines deem during the day and with the lights on only the bottom light shines. what could be my problem. I cant drive my car at night. also my cadillac convertor smokes after driving it for awhile or with the air conditioner on. my dash is digital and it will say stop engine but soon as i turn the a/c off it will go away. it kind of stutter also like its clugged up.
Old 06-30-2008, 05:56 PM
80 SS El Camino
Catalytic Converters are very unique. They contain precious metals that do some cool stuff. They convert Carbon monoxide to Carbon dioxide, nitrogen oxides to nitrogen and oxygen, and hydrocarbons to carbon dioxide and water. Your engines computer/emissions control rely on these principles to operate properly. If your catalytic converter is smoking I would replace it immediately! I have seen converters that were clogged actually glow at night. They will make your engine skip and sputter if clogged.
Next is your light. Sounds silly but did you check your bulb? If you pull it will it do the same thing? If the symptoms are still there without a bulb then it's obviously electrical. If it goes away then it's a 50/50 it was the bulb.
good luck
Old 06-30-2008, 06:35 PM
i changed the bulb and the same thing happen. maybe its a short. yeah my converter makes my engine sputter.
Old 07-04-2008, 10:32 AM
A misfiring engine will cause a converter to overheat to the point of glowing. The gas that's not being burned in the cylinder(s) is burning in the converter.
Brake light switch? cabrio Electrical 14 05-04-2007 06:08 PM
break light on..now what!? mrobby440 Suspension - Brakes - Steering 9 05-01-2006 12:30 AM
greased f. wheel bearings on 72 camaro, now brake light stays on bullheimer Suspension - Brakes - Steering 3 04-06-2006 09:43 PM
brake light 98 lumina strracer7 Electrical 0 01-23-2004 04:11 PM
Installing a 3rd brake light on a tinted window Jag Daddy Body - Exterior 3 05-30-2003 05:07 PM
