Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - my car idles high
Old 02-25-2013, 09:28 PM
DoubleVision's Avatar
DoubleVision DoubleVision is offline
Check the mechanical advance in the distributor, if it's developed a sticky spot, it can stick with the timing advanced a ways causing a high idle.
Also check for excessively worn primary throttle shafts on the carb.
