my car idles high - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-25-2013, 09:17 PM
my car idles high
my car idles high when i drive it .. sometime it idles perfect and sometime it goes high .. any suggestions ?? - chevy 350, headers, 4 barrel carb, cam -
Old 02-25-2013, 09:28 PM
DoubleVision's Avatar
Check the mechanical advance in the distributor, if it's developed a sticky spot, it can stick with the timing advanced a ways causing a high idle.
Also check for excessively worn primary throttle shafts on the carb.
Old 02-25-2013, 10:07 PM
mechanical advance ? .. the wires to the spark plugs or are there other wires to the distributor ??
Old 02-25-2013, 10:45 PM
Also check the return springs on the carb throttle. If the spring is weak or binding on something it can also cause a high idle.
Old 02-26-2013, 05:24 AM
poncho62's Avatar
Wiki Edits: 5
The mechanical advance is the springs and weights inside the distributor......
Also check for cracked or broken vacuum lines.
Old 03-10-2013, 11:42 AM
If the carb is a q-jet check the power piston spring. If the spring is too strong it will raise the primary jets at idle. More on this in cliff's book.
Make sure the secondary throttle plates are fully closed at idle. The secondary plates are closed by a coil spring on the secondary shaft. Just rebend the spring so more force is applied to the shaft. This is the problem I had on my q-jet & it took a long time to find it.
Old 03-27-2013, 07:48 PM
Thanks to all the comments ..... I fixed the problem ...
Old 03-27-2013, 08:18 PM
RWENUTS's Avatar
Really!!
What was it?
Idles high Toddclary Engine 24 04-22-2008 01:06 AM
Rochester 2gc idles high - stumped given what a simple carburetor it is. dmc12mk3 Engine 9 07-31-2006 03:53 PM
85' corvette idles high WakBordr7387 Engine 6 12-30-2005 01:33 PM
Can you build a High Performace Engine that runs idles smooth? Jag Daddy Engine 16 01-23-2004 03:11 AM
Engine Alive. But Idles to High zeeman19 Engine 3 07-09-2002 07:34 PM
