My Chevelle is a leaner - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-24-2007, 08:23 AM
Nichols6
My 1970 Chevelle is an inch lower on the drivers side than the passenger side.
I want to install new body bushing, springs and shocks.
I definitely want to use only the best parts available.
Don't want any junk on my ride.
Any suggestions on parts and additional causes to the leaning would be appreciated.
Thanks
Old 11-24-2007, 08:30 AM
Nichols6
lean what to do
Old 11-24-2007, 08:31 AM
31 five window
Last journal entry: Moving along with patch panels.
Go to a good air ride system then empty or passengers you can level accordingly and get a great ride.
Old 11-24-2007, 09:18 AM
After 37 years ... sagging springs on the drivers side is not unreasonable .. especially if the main driver was overweight.
New springs should cure the problem.
70-72 Chevelle Chevelle dash wiring Problem skeeveman Electrical 18 01-10-2011 07:44 PM
will a '69 Chevelle rear end fit into a '70 Chevelle? SMO'KUM UP Introduce Yourself 2 09-17-2007 07:15 AM
Need Help ! - Chevelle / Olds 442 Clutch Linkage MARSHMAN 442 General Rodding Tech 1 09-10-2007 08:53 PM
67 chevelle 12 bolt fit in 70 chevelle? 70chevelle327 Transmission - Rearend 11 09-11-2006 07:52 AM
Help With What To Do With A 66 Chevelle I bought - Trades? daveh Hotrodders' Lounge 17 03-29-2006 04:26 PM
