My Clay Smith cam - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-03-2008, 04:38 PM
My Clay Smith cam
Hi Guys,
Need a little input from all you hotrodders. I have a new Clay Smith cam my friend gave me. I will be rebuilding my SBC 400. I want to know what kind of buildup I would need to do to use this cam. Here are the specs.
318 degrees advertised duration , 276 degrees at .050 - 555 lift and ground on a 108 lobe centerline. I will be using this motor in my 2002 Chevy S10. It's backhalved and will be used for street and strip. Mostly strip. Have at it!!!!!
Thanks in advance.
Thom
Old 06-03-2008, 04:46 PM
That is a really big cam. You will need a lot of compression, gears, stall, intake, carb, head, and exhaust. Not sure you could drive that on the street.
13:1 cr min, 4.56 gears and a 4500 stall, 1-3/4 headers and 3 inch exhaust, 215cc head, victor jr intake with a 950cfm carb.
Old 06-03-2008, 05:01 PM
Yea, that cam is too big for you, why don't you send me a PM and let me know how much you want for it...
Old 06-03-2008, 07:11 PM
Wiki Edits: 31
I run a simmilar clay smith cam in my 200 I6 Ford.. 274/274 @.50 .495/.495.. but my engine is turbocharged so it's a whole diffrent ball game
Old 06-03-2008, 09:23 PM
what kind of buildup...SBC 400...will be used for street and strip. Mostly strip...
Block? What are you going to use for internals? Any ideas on the stroke you might want to use? Big deal too, how much in the budget? What head choice??? 23* or other?
I had an idea to use someWorld Motown Aluminum 23° Cylinder Heads
World Products introduces two great new cylinder heads for small block Chevy applications. First is the Motown 23° with 215cc intake runners. This Vortec-style head combines high velocity ports with a quick-burn style combustion chamber. This is perfect head for serious street performance. For larger displacement small blocks, as well as highly modified engines, World’s new 235cc intake Motown head is the answer. With huge 2.100” intake and 1.625” exhaust valves, coupled up with highly efficient port designs and Right Cast® technology, these heads flow incredibly well. The screw-in rocker arm studs are installed at 23° --the same angle as the valves. This assures optimum valve train geometry throughout the rocker arm arc. Offset rocker arms are required in conjunction with longer-than-stock valves to maintain the correct geometry.(+Technical Specifications)
in the 235 runner size for a 400 based build. Not a race motor, but a real thumper. I don't know anybody who has run these, so I could guinea pig myself out on them. You would probably be best off with a set of AFR Heads. There are some other awesome heads out there, depending onyour goals, how much your sled weighs/combo, how much head you'll need. What trans/converter, gear,? 4 link, slide a link, or type rear set-up? Slick, street radial, size?? Does it/will it hook? Give some more specifics on the rest of your combo. You're going to build this motor because this is the cam you have? If so, maybe sell that cam and figure out exactly what you'd like the mill to do for you ET wise. You can make 700+ with a stroker very easy, but there are limits if using a stock block. Have you thought about destroking?
I am not a compensated agent/endorser of any known product or business.
roller cam selection for my monte ss redbandit98 Engine 37 06-21-2008 11:39 AM
Cam button length/clearance..? mrdreex Engine 1 04-12-2008 11:17 PM
Cam Selection and Dynamic CR Arcuden Engine 8 03-23-2008 12:03 PM
Help Me Pick A Cam Canadian Charlie Engine 2 11-16-2005 02:11 PM
1970 Ford Clay Smith cam mustang Engine 1 09-30-2002 10:14 PM
