Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Is My Crankshaft Safe to Use?
Old 01-25-2013, 07:51 AM
BOBCRMAN@aol.com's Avatar
BOBCRMAN@aol.com BOBCRMAN@aol.com is offline
Look at the crank from the front end. You will see a "parting line" that runs up the front of the crankpin. If this line is 1/16-1/8" wide. The crank is cast. If the line is 3/8" or wider, the crank is forged steel.
Cast cranks last hundreds of thousands of miles in production engines. Unless you are building a 600 horse engine. Cast is fine.
The Following User Says Thank You to BOBCRMAN@aol.com For This Useful Post:
TN6vols (01-25-2013)
