Is My Crankshaft Safe to Use? - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 01-25-2013, 07:35 PM
BOBCRMAN@aol.com's Avatar
Originally Posted by cobalt327 View Post
I agree- I'll be by in a minute to haul it to the dump to save you the trouble.
Why is it that no one bats an eye at turning a cast 400 sbc crank down 0.200"(!!!) to fit it into a 350 block, but worry about a LJ steel crank being turned down 0.030"??
Amen.. I say Amen!!
  #17 (permalink)
Old 01-25-2013, 09:47 PM
1Gary's Avatar
Last journal entry: 383 dyno sym
Often times these threads ask questions that doesn't completely cover the total work needed.
Look at this analysis.
This engine has already gone through turning the crank once.
Now it needs it again according to his machine shop.
But we are rejecting his machine shop's suggestion the crank needs replacement.
Yet we are accepting the machine shop's inspection of the block.Well atleast that fact it isn't cracked.
Me??. The question I have is if we reject the machine shop's suggestion of a replacement crank,why would we accept that this block doesn't need a line bore now what would be a third time being repaired for bearings??. Rains down heavy on me is WHY??. What is creating all these bearings to be chewed up??. Is his crank bent??. Again before the third time isn't a charm,WHY??.
The Following User Says Thank You to 1Gary For This Useful Post:
vinniekq2 (01-25-2013)
  #18 (permalink)
Old 01-25-2013, 09:56 PM
vinniekq2's Avatar
Igary,thanks for that post. I always assume that all engines get some kind of blue printing.Remembering the basics is important. The machine work needs to be accurate and cranks need to be straight. well chosen parts adds to a better engine.
dont rely on luck,do it right the first time.
Is This Safe? Jeff The Ruler Engine 6 06-17-2010 04:33 PM
Be Safe Out There 1ownerT Off-Topic 7 08-25-2007 03:23 PM
Crankshaft turned to .020 rod and main , is it safe? 74chevyflat Engine 3 09-01-2006 11:22 AM
would this be safe enough? 53LEDSLED Suspension - Brakes - Steering 4 01-30-2006 07:35 AM
Is this safe? almega Engine 8 06-19-2005 05:47 PM
