My DA sander broke :( - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-12-2003, 03:44 PM
Rubberman2003's Avatar
It locked up, this is a sad sad day indeed.
Old 11-12-2003, 05:17 PM
crazy larry's Avatar
Last journal entry: better comparison before and after shots
R-Man......
make sure the allen head screw in the rotating assembly didn't back out and bind it up...... there should be a little 'window' where you can see the screw i'm talkin' 'bout.....
if it did freeze up, then why haven't you oiled your tool lately????
Old 11-12-2003, 05:37 PM
BstMech's Avatar
NYOFP4RJ3CHRIS
Re: R-Man......
The correct oil is NOT made by Johnson&Johnson...........unless it's FOR your Johnson.
Old 11-12-2003, 05:43 PM
troy-curt's Avatar
Shop Owner And Troll Hunter
The bearing doesn't last long with a lot of use.
You can get them at most parts stores for a couple of bucks.
One of the gm alternator bearings is the same.
I keep several on hand, seem like I replace one a week.
Troy
Old 11-12-2003, 06:34 PM
Well i guess im not 100% sure it the bearing, heres what it does. THe place where it orbites will rotate fine with my hand, but as soon as i pull the trigger it locks in place, its wierd, and i have oiled it before every use like im suppost to.
Old 11-12-2003, 06:46 PM
troy-curt's Avatar
Cool
If you can spin the desk by hand and it's smooth and spinning then the bearing should be all right.
Does it spin but not orbit? If it does the locking mechanism is engaged.
Troy
Old 11-12-2003, 06:59 PM
Kevin45's Avatar
Just one of the guys
Last journal entry: Vise jaws
Sometimes...somewhere along the line...you just gotta thump your tool.
Old 11-12-2003, 08:39 PM
wont spin or rotate
Old 11-12-2003, 09:42 PM
BstMech's Avatar
NYOFP4RJ3CHRIS
Or to coin a phrase we recently learned from our friends across the pond, sometimes you just gotta' "toss" it.
Old 11-12-2003, 11:48 PM
Nos's Avatar
Nos Nos is offline
ok sometimes this works.. get pist.. and throw it at the wall.. have a beer.. or in my case.. a soda.. and then try it.. should work.. if not.. repeat process 2 times.. and if not.. then take it to the store and Yell and scream till they give u a new one..
Nos
N|O|S
Old 11-13-2003, 12:10 AM
I'm tellin' ya man......
there's an allen head set screw in the inner collar. (if you got a cheap da like me) look in the debris/oil exhaust hole thingy, rotate it around, and see if there isn't a bolt thats backed out too far........
