My DD needs help! - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-15-2008, 05:14 PM
Everything is HAMMER!
My DD needs help!
Hi, guys my 88 mercury topaz 2.3l needs help keeping cool. I know the problem is the cooling fan, it won't turn on no matter how high the temp. goes, i've checked the plug going into it with a multi-meter, the ground shows no resistance to battery terminal ground, and the positive side shows 12.5v. But it still will not turn on, i've tried wiggling the plug in the socket but all attempts turned out the same.
Who else thinks the fan motor needs to be replaced, i could really use some professional opinions before i go throwing money at it.
Old 08-16-2008, 05:34 AM
Try hot wiring the fan and see if it turns on. You can see 12.5 volts with an voltmeter but a voltmeter only needs a milliamp, or so, of current flow to give a reading. When the fan tries to pull 5 amps through the same circuit the current may not flow because of a bad connection. A good way to test the circuit is to make a tester by connecting a headlight into the wiring for the fan. If when the engine heats up the headlight comes on you can be pretty sure the fan wiring is okay.
Old 08-16-2008, 11:36 AM
wired the fan straight to the battery and nothing happened so, it looks like its time for a new motor.
Old 08-16-2008, 08:16 PM
Yes it does.
Old 08-27-2008, 08:05 AM
ChevelleSS_LS6's Avatar
Jeep XJ and a Javelin
Last wiki edit: Compression test
Last journal entry: August 9, part III
Wiki Edits: 7
if you can't find one at a boneyard, try a universal aftermarket fan and attaching it to the stock fan shroud/mounting plastic part.
Buy an econobox for a DD? ChevelleSS_LS6 Hotrodders' Lounge 19 05-21-2007 07:13 PM
another DD thread 82c10 Engine 0 12-23-2006 06:52 PM
Is an Eagle an AMC or Dodge? Wifes new DD Blackdog Hotrodders' Lounge 11 04-17-2006 11:37 AM
DD My Street Stock Engine? Mike_82 Engine 1 12-20-2004 07:23 AM
cam suggestion for DD with 1.74s COCHEV Engine 2 02-25-2003 11:22 PM
