hello
Hello Up & Coming nice job on your 383 stroker. I just did a build on a 327 and would like to ask if you would mind running ur desk top dyno for me on my specs if you wouldn't mind. Here are my specs
327.40 over 333 sbc voodoo cam Duration @ .050 (Int/Exh): 219/227 Gross Valve Lift (Int/Exh): .468/.489 LSA/ICL: 112/108 291 fuelie heads, 2.02s cast iron gm ported and polished & deshrouded hei distributor 65,000 weiand team g single plane intake hooker shorty headers, i know i need longer tubes in the future flat top pistons I think CR is around 10.1 maybe a little under not to sure. Thanks in advance if you have time! |
ok i need some specifics
starting with the heads are they stock heads or aftermarket? full port polish or pocket porting? Intake and exhaust valve size chamber size in CC head gasket thickness has the block been decked? Carb size cam intake center line exhaust center line cam lobe center angle yep thats what i need to get accurate with your application |
more specs
670 holley vac secondaries gm 3917291 fuelie heads 2.02s/1.6 valves full port polish and deshrouded in bowls 64cc 0.028" head gasket I think?? block has been decked I am pretty sure motor is bored .40 over cam lobe center line on intake is 108, here is the cam card to make sure I don't give you the wrong info? never done a dyno before heheh http://www.lunatipower.com/Product.aspx?id=1983&gid=287 |
Hey Up.
Does the program tell you anything other than what's on the attachments of your orignal post? |
The one thing that will get you into trouble with a desktop dyno is head flow. On my DynoSim, I usually factored the flow down by some numerical value, either .9 or .95, depending on how skewed I thought the manufacturer's figures were. In other words, 250 times .9 equals 225.
You will probably find that the most benefit will be made with a free-flowing intake and exhaust system. I was able to pick up or drop off a hundred hp just by changing the intake manifold, carb and exhaust. A tuned set of headers is good for about 50 hp, an RPM intake is good for about 40 hp over a standard low-rise Performer and the more carb you give it, the higher the numbers. As long as you realize that a 600 carb will feed 90% of the 350's out there, you'll be ok. |
dyno run
Up & Coming,
Thanks for your time and I can't believe it is making that much hp? I thought around 325-350hp max, hopefully someday I can do a chassis dyno for exact numbers in real time. Thanks you for giving me some insite into my curiousity. Sorry vague on some of the specifics. What are the cam specs for a original 327 rated at 375hp back in the day? |
Lol tech is the king of this stuff guys im still an amature in comparrison to him and by no means do i kno everything but i learn lots here, tech does ur dyno sime have more advanced input compaired to mine bc there is a whole bunch of things my engine has going for it that i couldnt input
The DynoSim 4.2 is on my computer in Phoenix. I'm currently living in North Carolina and have no dyno software on this, my daughter's computer.
If I were to purchase a system today, it would be these two discs... http://www.proracingsim.com/dynosimmainpage.htm http://www.proracingsim.com/camdiskmainpage.htm The additional 6000 cam profiles will be of great help to you when you need to try 6 or 8 different grinds to find the sweet spot in a given combination. |
Hey Tech. It would be a good chance to check out the free 10 day trial of the Engine Analyzer Pro. I've used it on both my work and home computers and I'm out of IP addresses to get it again. I would really appreciate your input to the quality of this program compared to the Desktop Dyno stuff as I do want to buy something soon. Analyser |
| Dyno results not what I expected. | Hawkfan | Engine | 17 | 07-16-2011 07:17 PM |
| My 383 sbc dyno results | v8hed | Engine | 7 | 04-21-2011 10:32 AM |
| Desktop Dyno2003 on Chevy engine build...can somebody comment on my results ? | y2k600f4 | Engine | 4 | 02-20-2009 10:34 AM |
| 406 Dyno Results | Steve karch | Engine | 5 | 12-20-2006 08:04 PM |
| Strange dyno results | dion | Engine | 28 | 09-01-2004 05:19 PM |
