my dist. moved significantly @ 5000 rpm?? - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-16-2010, 05:02 PM
Show me the money !
New build, gm400 w/hydraulic roller. Today I brought her up to 5000rpm. and for the second time, the dist. retarded itself significantly. I thought It was cranked down pretty good, Although I could still move it by hand, It seemed tight enough. I am afraid of stripping the bolt in that cheap aluminum. I did pull the dist. and it seems to be OK. From what I can see, there is no damage on the cam gear. What causes this ? I did set the cam play w/ a dial indicator . ??
Old 03-16-2010, 05:10 PM
eloc431962's Avatar
Evil Wicked Mean And Nasty
Wiki Edits: 37
Are you using a stock hold down or a after-market like chrome?
Cole
Old 03-16-2010, 05:13 PM
Show me the money !
Cole
After mrkt. chrome
Old 03-16-2010, 05:15 PM
eloc431962's Avatar
Wiki Edits: 37
Get a orignal piece (stock) it should hold it then, I never had much luck with the after-market chrome stuff in that area. Or any area at that,JMO
Cole
Old 03-16-2010, 05:29 PM
If you can turn it by hand, then it will definitely turn at higher RPM. Smart to not put too much torque on that aluminum intake. Pretty(?) chrome is not very tall in the performance world.
Trees
Old 03-16-2010, 05:32 PM
Sinister's Avatar
Get a hold down that uses a stud. Won't strip that way.
techinspector1's Avatar
Wiki Edits: 326
The best thing I can say about those low-buck chrome engine pieces is that they're low-grade junk.
The only chrome dress-up pieces I ever had work correctly were OEM pieces that I chromed myself or pieces that I fabricated from scratch and had chromed.
Old 03-16-2010, 05:35 PM
eloc431962's Avatar
Wiki Edits: 37
I agree 100% Richard, Just like those dang chrome thermostat housings . Have a feeling we might just offend someone on this subject.
Cole
Old 03-16-2010, 06:39 PM
Show me the money !
Thanks for all the input. I agree, I did not have a hold down and needed one, that was readily available. It must be because it is to soft and slippery, I was thinking, maybe if I cut some grooves in it if it will help( you know, the dist.side) I like the stud idea too, Think I will locktight a stud in there for starters. By the way , after further inspection, It appears the dist. gear is wearing low on the gear,( in both the old and new engine) and Im not liking it, It was a cheap, $99.00 after mrkt. dist. and its 8 yrs. old and it clearly doesn't have a GM gear on it. I have decided to go with a new one.(GM remanufactured) instead of after mrkt.
Old 03-16-2010, 06:44 PM
eloc431962's Avatar
Wiki Edits: 37
What are all the specs of your engine? You may need to go with a MSD Ignition or something similar JMO.
Cole
Old 03-16-2010, 06:58 PM
Show me the money !
Cole
I have the MSD w/the rev. limiter in there. (on a stock dist.)
10:1
comp 270 hyd.roller .495 .502
stock con. rods
Comp. retro Hyd.lifters, W/link bar
RHS 2.02 -1.6 220 intake runner 72cc heads
weiand stealth intake w/ 750cfm
Old 03-17-2010, 05:45 AM
345 desoto's Avatar
Location: Skaneateles, NY Summer/Port St.Lucie, FL Winter
Are you sure the hold down bolt wasn't bottoming out before clamping sufficiently? I agree with the stud suggestion. Anything that threads into aluminum should use a stud/nut whenever possible...
Old 03-17-2010, 06:17 AM
Rickracer's Avatar
ASE Master Tech, Fabricator
Last wiki edit: Taurus 2-speed fan control wiring diagram Last photo:
If your hold down is nice and beefy, you may just need to rough up the part where it contacts the distributor and snug it down better with a stud,
Old 03-17-2010, 10:38 AM
If it is loose enough to turn by hand it aint tight enough to hurt the threads. Snug it till you can't turn it.
267 small block chevy chevellecamino Engine 59 02-03-2012 02:04 PM
Build for Hp or Torque? Venturat Engine 76 09-23-2008 10:22 AM
Whats wrong with the performer rpm cam?. 7fastelc0 Engine 19 12-09-2006 05:49 PM
Single plane and duel plane manifold stonedchihuahua Engine 21 01-06-2003 11:56 PM
Built 350 stops making power at 5000 rpm??!! chevyelc81 Engine 2 06-11-2002 10:33 PM
