Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - My DIY tig welder..
  #52 (permalink)
Old 01-04-2006, 02:53 PM
Travis Rankin Travis Rankin is offline
Last journal entry: Tube front clip
with this all hooked up you know have a variable welding supply controlled by a pot.. you can see the main power control pot sticking out of the back of the welder on the right hand side.
Becuase Volatge dividers work on resistance and there is so much wire the 25VDC we started with max's out at the field coil input at about 18VDC wich is great as all it needs is 12VDC. but I like ot be able to crank it up that extra little bit..
But!! if I was hooking this up to a 240VAC wall input I would end up with more power there and might have to limit it a bit so not to have a melt down.. I am at 208VAC input so we are good to go.
next up foot pedal control
