Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - My DIY tig welder..
  #58 (permalink)
Old 01-04-2006, 11:34 PM
crazy larry's Avatar
crazy larry crazy larry is offline
Last journal entry: better comparison before and after shots
I'm with you.
do the resistors in the voltage dividers have to be any specific resistance? or any as long as they are identical?.....n/m, i see you spec'd 0.1 ohm.
if we need to step down to 12 vdc, is it necessary to start with the 240 vac? Is 120 vac insufficient?
Travis, thanks for your time. I do appreciate it.
