We're winning the case!
Hotrodders Bulletin Board > Tech Help > Garage - Tools
Closed Thread
  #76
Old 01-05-2006, 02:02 PM
Travis Rankin Travis Rankin is offline
Originally Posted by rampage40
fantastic project
can you tap 110 volts of some where when using a gas garden tractor as a power unit?
max
you mean to run grinders and other brush type motors.. (no variable speed drills though)
Yes with full field coil current and the rpms maxed out, you cun run those off of the welder output. just wire in an electrical box.
Old 01-05-2006, 02:10 PM
Originally Posted by IMRobber
Travis,
Thanks for doing this! I know it takes a long time to do and I do appreciate it. Will be getting together with some friends and we are going to be looking at building one of these.
Another friend's dad has a second alternator in his Jeep setup as a DC stick welder, just in case he breaks something when he is out 4 wheeling. I believe this is similar to your idea. Neat idea using the sliding light dimmer for the foot control.
I have attached a Word document that I made from your posts along with some of the posts where the content adds to the discussion. Hope it helps in creating an all encompassing document in the future.
Now, if someone could just come up with a home made plasma cutter...
Regards,
Rob
Right on.. I would do what i did though and get rid of one of the alts and wire in a ford regulator, so the alt will charge and weld when you need it.. its very reliable and will be a lot neater under the hood. I had one on my old trail rig, and i have one on my 67 chev ramp truck.
A plasma cutter is pretty simple as well.. you just need compressed air and alot more power and volts. I was about to do it, when I got an 80Amp plasma machine for free... they said it was broken and wasn't worth fixing, a couple small repairs and adjustments (both $$ free) , and I got a sweet plasma cutter that will cut 1" plate.. whooohoo lucky me
it happens all the time keep your eye out.. once the machines mess up, they think its cheaper to by a new one.. but for a handyman they are simple to dial in again
Old 01-05-2006, 02:46 PM
damn 2600 views allready I should be getting royalties maybe i could afford to do hf start , pulser, as well as AC for aluminium
Old 01-05-2006, 06:13 PM
crazy larry's Avatar
crazy larry crazy larry is offline
I'm taking a sick day tomorrow so I can go scrounge the electrical stores and junk stores and just not go to work. thanks again.
Old 01-05-2006, 06:52 PM
Jon's Avatar
Jon Jon is offline
Hotrodders.com Administrator
Jon's barnstar
Wiki editor
Wiki Edits: 6,687
S10Fan has emailed me a 15-page PDF with photos and diagrams for a DIY TIG welder. I'm looking into the copyright issues right now. If anyone has any information on freely posting this PDF file, please PM me ASAP. The author is "John Mills".
DIYTIGWelder.com is one lead, but they've been taken offline. We should be able to view some of their pages at Archive.org to see if the same file was offered for free, but Archive.org is temporarily down right now too.
Meanwhile, here are some related resources listed on other websites:
Various DIY welder plans:
http://www.green-trust.org/junkyard...elderPlans.html
TIG Handbook:
http://www.millerwelds.com/education/TIGhandbook/
Old 01-05-2006, 06:58 PM
Is there a copyright on it somewhere?
Old 01-05-2006, 07:05 PM
docvette's Avatar
docvette docvette is offline
docvette's barnstar
Wiki editor
Last wiki edit: Rebuild an alternator
Wiki Edits: 12
Doc here,
The Name John Mills brings "No Results " on a copyright documents search..
So I would say this material is probably public Domain.
Doc
Aftermarket Solutions
Electronic & Electrical
Innovations
Old 01-05-2006, 07:32 PM
32vicky's Avatar
32vicky 32vicky is offline
Tomorrow Will Be a Better Day
Old 01-05-2006, 09:28 PM
Jon's Avatar
Jon Jon is offline
Jon's barnstar
Wiki editor
Wiki Edits: 6,687
It may still be under copyright, even if it's not overtly registered. grouch is very knowledgeable about digital rights management and intellectual freedom, maybe we'll see what he has to say about this.
If not, we can just do what lowROLLERchevy is doing in this thread. We had to take T-Bucket plans off of the board due to copyright concerns, so he's drafting a set of plans to give away for free to the rodding community .
We can do the same thing with plans for a DIY TIG welder.
Old 01-06-2006, 04:12 PM
matthewj matthewj is offline
Hello everyone, newbe here, nice post Travis. Here is something I found when doing a search some Kool Info... http://www3.telus.net/public/a5a26316/TIG_Welder.html
Looks a little invovled though.Found it here http://www.hobartwelders.com/mboard...ead.php?t=12905
Old 01-07-2006, 08:28 AM
1bad66ss 1bad66ss is offline
Thanks Travis, this is what hot rodding is all about sharing GREAT ideas
http://members.cardomain.com/1bad66ss
Old 01-07-2006, 10:41 PM
pigman pigman is offline
Now that is nice, I couldnt understand why you would need all the overhead of an electric motor and alternator. Solid state is sooo nice and clean im gonna start building that one!
Thanks fo that link!
Old 01-09-2006, 04:15 PM
rainbird-too's Avatar
rainbird-too rainbird-too is offline
Does the transformer have to reduce to 25vdc our is less our more allright would a door bell tranformer work I believe they come in the 120 our 220 volt versions I dont recall the output though if it is 12 volt out 40 volt our 25 volts
Thanks for all the info.
I will definatly be building one for my self, I've been wondering what I was going to do with this pile of old Alts. I have taken off of old trucks .
Thanks Ray
Old 01-10-2006, 11:18 PM
FrankR FrankR is offline
I might have to just dust off my old electronics text books and re aquaint myself with some things.
I need help over this brainfart I have though. Admittedly I need to read more on TIG to better understand, but looking at the schematic....
The 240AC to BR1. Is that an input or an output? I mean do you plug this into your house 220v outlet or what is it for? Not sure I follow.
Can you be more specific about the specs on the electric motor you are using? What about the Delco alt? What would be a likely vehicle to look for such? (I'm a Ford guy. Not a lot of experience with Delco alts.)
Old 01-11-2006, 05:21 AM
302 Z28's Avatar
302 Z28 302 Z28 is offline
[QUOTE=FrankR]I might have to just dust off my old electronics text books and re aquaint myself with some things.
The 240AC to BR1. Is that an input or an output? I mean do you plug this into your house 220v outlet or what is it for? Not sure I follow. [QUOTE]
Looks to me like that is the same 240vac supply that his 5hp motor uses and he just used that for the 240v to 25v step down transformer for control voltage.
Vince
Closed Thread
Back to top
Search this Thread:
Advanced Search
vB code is On
Forum Jump
Similar Threads for: "My DIY tig welder.."
Harbor Freight TIG oldred Garage - Tools 54 02-22-2009 05:00 PM
DIY TIG Welder 59Spitfire Garage - Tools 3 12-14-2007 05:11 PM
Mig to Tig conversion? Billy Boy General Rodding Tech 8 01-14-2006 12:28 PM
Good quality TIG welder which one?? sevt_chevelle Body - Exterior 8 01-05-2006 06:58 PM
Seeking used TIG welder rpaulsen Body - Exterior 3 02-03-2004 11:19 PM
