Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - my doors got stretched
Old 11-25-2004, 05:59 PM
oldred oldred is offline
If its ok I would like to put in my 2 cents. Some time back I created one of Martinsr's totally ruined,throw it in the trash parts, a 64-1/2 mustang deck lid. It took a new lid to correct that little mistake and from then on I was a lot more careful. I was using a pressure blaster at 120 lbs. pressure and regular sand(for lack of a better description)and even though I moved quickly and did not hold the blast stream in one spot when I stopped to check my progress I was shocked at the amount of warpage! Now I try to avoid sand blasting but I have used a suction blaster at 90 psi with no problems so far. I am not saying that a suction blaster is ok and will not damage a panel but it does seem to me to be a lot safer if someone does decide to sand blast. Could it be that the sand velocity is lower in a suction type blaster?or have I just been lucky so far?
