my drag/landspeed racing progress log ( 89 twin turbo camaro ) - Hot Rod Forum : Hotrodders Bulletin Board
Hot Rod Forum : Hotrodders Bulletin Board > General Discussion> Projects/Builds/My Ride
Old 05-24-2013, 02:16 PM
Project89's Avatar
since i just buttoned up my twin turbo iroc i figured id log my progress with it this year for u guys
my goals for the year are
#1 1/4 mile run 9.50's or better
#2 salt flats join the 150 and 200 mph club
depending on money the 200 mph club may have to wait till next year as the fire supression system, land speed tires , and other saftey equipment i need to make the car legal for a 200mph pass is not exactly cheap
for those of u who have not been following my build thread the car is setup as follows
engine
0010 block .030 over
factory forged crank
handpicked reman rods/arp bolts
speed pro .120 popup domed pistons
summit 224/224 cam
ported 882 heads
ported tpi intake
120# injectors
3 vette zr-1 fuel pumps
single fogger nitrous system 35/50/75/100 shot
turbo system
homeade twin turbo headers
pair of gt3076 turbos ( upgrading to a pair of gt3582's )
pair of 38mm wastegates
single 34x12x4 air to air intercooler
megasquirt 1/2 running ms extra with launch control/traction control and nitrous control
driveline
4l80 with full manual vb ( currently out for a rebuild )
9 inch rear
suspension
lcarbs
boxed stock lca's
lakewood drag shocks
front suspension is stock for now
still need to install 10pt cage and frame connectors ( hopefully in the next week or so as both are sitting in my storage unit )
anyways that covers most of the car and the build.
heres a video the other day of when i downgraded the megasquirt to an ms1 from ms2 thinking my ms2 cpu was bad turns out the injectors i have just wouldnt run with the settings for low-z injectors in the megamanual
and here it is the follwing day with the base tune cleaned up just enough to drive it home
anyways theres my car , theres my goals , hopefully ill reach my goals this year, feel free to comment, laugh , tell me im crazy lmao whatever ,
Old 05-25-2013, 10:54 PM
Project89's Avatar
well got her home and started tearing down some of the turbo stuff so i can clean up the pipes and wiring , also got the base tune worked on idles and revs so much nicer now
as u can see lots to do to make it look good
Old 05-25-2013, 11:03 PM
Proud LOSER
Let me be the first to say I fkn love it.....I think this was one you bought carb'd and a little butchered iirc?
Very cool car....hope for now you leave the 80's centerlines on it.....
Can't wait to see more
Dave
Old 05-25-2013, 11:06 PM
Proud LOSER
PS
After seeing what Marty did with the grenade your goals aernt "crazy" lol....maybe lofty....but not crazy
Old 05-25-2013, 11:25 PM
Project89's Avatar
Dave
a lil butchered is an understatement
btw see the big line hooked to the front of the carb under the fuel inlet in the picture above , po had it hooked to the return line thing would suck fuel up the return line into the carb
this is what the previous owner left under the hood ( all the original hacked efi harness )
the centerlines are staying , the tires on the rears were shot so i put those chrome rims on it for now , picked up all 4 rims and 4 new tires for 200 bucks
going to throw the new tires on the centerlines but im going to dismount the old tires and give the centerlines a proper polish job while they dont have tires on them. i did a quick polish job on 2 of them last year and they look so much better cleaned up
heres 2 pics of the fast polish job i did last yyear
Old 05-25-2013, 11:28 PM
Project89's Avatar
PS
i should be able to hit those goals with room to spare , ive got more engine and turbo then marty has, though he has a much better tpi setup then i do
Old 06-07-2013, 04:24 PM
Project89's Avatar
2 packages sitting at the post office for me to pick up , hoppefully its my pair of gt3582 turbos, and my 4 stage boost controller
Old 06-22-2013, 10:27 PM
Project89's Avatar
might take it out tomorrow and get some really good driving vids , couple friends wanna take a trip up the mountain to the ski resort and back , if i go should get some good footage
Twin turbo iroc - YouTube
"> Twin turbo iroc - YouTube
" type="application/x-shockwave-flash" width="425" height="350">
Old 06-24-2013, 08:42 PM
Project89's Avatar
new goal !!!!!!!!!!!!!!!!!!!!!!!!!!!
got my new boost gauge old one only went to 10 psi , new goal is to swing this gauge needle past the +30 , i already know the motor holds together at 22 psi , how much damage could another 8 psi possibly do lol
Old 06-30-2013, 04:10 PM
Lookin good!
Old 07-11-2013, 11:11 PM
Project89's Avatar
thanks to a board member on my local car forums i picked this up today for 75$'s
champion 3 core radiator and fan
its 18.5 tall , 27 wide , and 2.5 or 3 inch thick , it was originally out of his nova but the size was close enough i figured it would work in the iroc and i was right , witht he exception of having to bend the trans cooler lines just a tad to make it fit and also trim the upper radiator hose about 2 inches
btw the champion units made for our cars ar 18.5, x 30 x 2.5 so this one was only 1.5 inch narrower
i got it installed tonight and with only a single stock fan it droped 40* out of my coolant temps , need to get a mounting kit for the fan i got with it
Old 07-12-2013, 07:44 PM
Project89's Avatar
still have to make good brackets for it but it droped in nicely tons more room to now that dual fan setup is gone
Painting my twin turbo camaro ( helppppp) Project89 Body - Exterior 8 09-15-2012 07:41 PM
twin turbo 86 IROC camaro biggunn770 Introduce Yourself 2 02-22-2008 08:09 PM
Drag Racing only ? Shorty Thompson Transmission - Rearend 5 07-12-2006 11:15 AM
drag racing femadorob420 Hotrodders' Lounge 2 12-13-2003 05:43 AM
85 camaro with 383 stroker with nitrous oxide or twin turbo? camaro dan Engine 0 10-08-2002 07:18 PM
