my egr valve needs help - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-11-2004, 01:10 PM
eM-K's Avatar
New Member
I have an 84 camaro 305 v8... and my egr valve is sticking open. I went to autozone and it costs 62 bucks. Is a replacement necessary or is it possible for me to spray the thing up with carb cleaner and hope it "unsticks". Also in my stupidity I bought the wrong egr valve because i didnt look at the numbers and because it was 30 bucks cheaper. What will happen if I use this egr valve.. it seems to look like it would fit right on there but what would i be doing to my engine???
Old 11-11-2004, 01:19 PM
poncho62's Avatar
Wiki Edits: 5
If it is seized, you may be able to free it up.................if the diaphragm is split, it is uekered.
It will run ok without it, but not as clean.
Old 02-15-2005, 10:00 PM
rick458's Avatar
Wookie
On the exhaust valve Diaphram what vacuum does it operate at?
Rich
77 Impala
74 260Z (a Work in SLOW Progress)
69 Big Block Chevelle (long gone)
Semper Fi My Brothers
Old 02-15-2005, 11:42 PM
Matts99Sierra's Avatar
pull the EGR off and use block off plates and cap the vaccume line. unless your EGR is electronically controled you dont need it. just make sure you block of the ports for it.
