Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - My engine Build
Thread: My engine Build
Old 07-07-2008, 09:05 AM
Ozz1967's Avatar
Ozz1967 Ozz1967 is offline
Air Force Guy
Originally Posted by C-10
Dished pistons... woulda went with Flat tops. (IMO)
Sportsman 2's good investment...
Q-Jet... OK, but I'd run a Holley HP series 750 vac. sec.
700 R4 with 3.73... Awesome. (hook up that TV cable for cryin out loud)
VooDoo's are a Hyd. flat tappet? If so, use Shell Rotella oil.
This T/A should move out.
This voodoo is a roller cam.
I also wanted to go with the dished to keep the compression down a bit in order to be able to rum pump gas. WIth the way it's still going up I dont want to "have" to run premium all the time.
