My Engine Build Thoughts - Give me your input - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-22-2013, 04:40 PM
S10 Racer's Avatar
http://www.warsprints.com
Last journal entry: W.A.R. (Wingless Auto Racing) Sprint Car Racing
Going in our Wingless Sprint car. Give me your thoughts or suggestions. Thanks
SBC 350 +.060
ROD: Lunati 6"
CRANK: Scat 3.75 Stroke
PISTON: SRP
Piston Style: Dome, with two valve reliefs
Piston Material: Forged aluminum
Compression Distance (in): 1.125 in.
Piston Head Volume (cc): -7.00cc
Wrist Pin Style: Press-fit or floating
Pin Diameter (in): 0.927 in.
Piston Ring Thickness: 1/16 in. x 1/16 in. x 3/16 in.
Notes: Oil rail support included.
CAM: Howards Cams
Mechanical Roller Tappet
Basic Operating RPM Range: 4,200-8,000
Intake Duration at 050 inch Lift: 261
Exhaust Duration at 050 inch Lift: 265
Duration at 050 inch Lift: 261 int./265 exh.
Advertised Intake Duration: 293
Advertised Exhaust Duration: 297
Advertised Duration: 293 int./297 exh.
Intake Valve Lift with Factory Rocker Arm Ratio: 0.620 in.
Exhaust Valve Lift with Factory Rocker Arm Ratio: 0.620 in.
Valve Lift with Factory Rocker Arm Ratio: 0.620 int./0.620 exh.
Lobe Separation (degrees): 108
Camshaft Gear Attachment: 3-bolt
Intake Valve Lash: 0.022 in.
Exhaust Valve Lash: 0.022 in.
HEADS: AFR
227cc Raised Intake Runners
59cc Combustion Chambers
2.100 Intake Valves
1.6 Exhaust Valves
Howards ProMax Mechanical Roller Lifters
ROCKERS: T&D Shaft 1.5
INDUCTION: Hilborn 2-7/16" Mechanical Injection (Alcohol)
Old 02-22-2013, 04:47 PM
vinniekq2's Avatar
use 1 7/8 headers.
Are you porting the heads(tweeking) or using as is? The 227s are good heads.
not sure what power on alcohol,but those parts would make 600 plus on gas
Old 02-22-2013, 04:49 PM
Banned
Please tell me you're not using a stock block. You have some nice parts that may be able to make some nice power- but a stock block will never last with that.
Also, JMO, but I'd go easier on the cam lobes and increase the rocker ratio- unless you're running a much larger than stock cam core, which you may be.
Old 02-22-2013, 04:57 PM
vinniekq2's Avatar
ap72,those are standard lobe sizes for that type of roller cam. I use shaft rockers for my street car,netting 640/600 ish actual lift after adjustment for solid rollers.
for 8,000 rpm shafts are almost essential.
To get bigger than 420 lift lobes,usually you go for the block that takes a bigger cam in the raised position.
Old 02-22-2013, 05:59 PM
S10 Racer's Avatar
Vinnie,
The heads are race ported from AFR. My main concern was using the dome piston with the small chambered heads but the dome is not that much so it should be fine. I'm figuring about 14:1 SCR with those pistons and heads which should be great for alcohol.
AP72,
I'm hoping to get a Dart SHP block for this build.
Old 02-22-2013, 06:11 PM
vinniekq2's Avatar
My 227 heads were ported out of the box also.I still had more done.The cnc process leaves some flow on the table that can be cleaned up quickly and easy.we picked up 10 cfm
Old 02-22-2013, 06:13 PM
vinniekq2's Avatar
If you are changing blocks,build a bigger bore engine
Old 02-22-2013, 06:40 PM
S10 Racer's Avatar
I'm thinking a Dart SHP 400, 4.125 bore to start with. That will give me some room for future bores.
Old 02-22-2013, 06:48 PM
vinniekq2's Avatar
is there a cubic inch restriction? you have up to 440 cubes safely in thsoe blocks,and afr makes 245 cc heads
Old 02-22-2013, 07:21 PM
S10 Racer's Avatar
Nothing over 410 right now. How many cubes would my setup support without changing anything but bore size?
Old 02-22-2013, 07:33 PM
Banned
They may be "standard" but those lobes and the spring pressures they require are going to severely stress out a stock size core. One of the sbc's biggest faults in stock form is the tiny cam core, the other is the port arrangement.
An SHP or SHP Pro block will allow you to step up in core size- I definitely would to get more stability and less wear.
Old 02-22-2013, 07:49 PM
vinniekq2's Avatar
are you allowed to build a 402 with SB-2 heads?
Old 02-22-2013, 11:31 PM
flat top pistons have a better flame travel giving you a better complete combustion of fuel, that in turn equals more hp and better flow. plus what you lose in compression from not having the dome you can make up for in your gasket if you want
put a really good 9 way adjustable timing set in it so if you need you and take that 108 cam down around 102 to 100 if needed for banking.
use a electric water pump and a crank driven fuel pump with a emergency shutoff and by-pass
use a magneto for ignition, you going to need all the output and reliability you can get
if you don't have the hilborn yet, I would you a duel rons flying toilet injection, more reliability and better adjustability plus its not remanufactured from 40 year old parts and will cost you the same money
Old 02-22-2013, 11:55 PM
S10 Racer's Avatar
Yeah I could, there is no rule on that. I'm not familiar with the SB-2 stuff but I know Nascar use to use that.
Old 02-23-2013, 12:04 AM
vinniekq2's Avatar
nascar 360s make around 900 hp. 402 is bigger and you have fuel injection and alcohol.
not cheap
ZZ502 Chevy BB Engine Build - Thoughts? NikoG Modern Electronic Engines 4 10-12-2012 05:47 PM
Engine build thoughts??? 8843astro Engine 19 05-14-2009 02:01 PM
Carb Tuning Input/Thoughts (blower) camaroman7d Engine 20 12-16-2008 03:22 PM
aluminum firewall thoughts (seeking input) toolman1967 Body - Exterior 6 03-12-2008 06:46 PM
need input on engine build-photo article stuffola crazy larry Hotrodders' Lounge 24 09-23-2003 11:02 AM
