is my engine combo correct? - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-30-2009, 08:57 PM
351w bored 30 over, 10.1 compression,roller rockers, 200cc pro comp heads 202 intake 186 ex.68cc chambers cnc machined , isky 280 mega cam hydraulic 232 duration 517 lift. super victor intake manifold, 850 double pumper, c-6 trans, 2500 stall, tranny brake, 4.88 gears full spool, 29/10.50/15 hoosier slicks, the car weighs 2600 pounds with me in it. is there anything i need to change? what sort of ET times am i looking at?
Old 08-31-2009, 06:29 AM
ericnova72's Avatar
More for Less Racer
Stall is about 1500+ rpm too low, 3600 would be about the minimum I'd use. 12.0's with what you have now, 11.50 or better with 4000 stall. Solid cam would really help too.
Old 08-31-2009, 07:12 AM
Banned
I also wouldn't use Pro Comp heads for anything but scrap metal, they're poorly cast, poorly machined chinese crap. a LOT of engine builders won't even touch them at all. Spend the extra couple hundred of bucks to do it right and get some quality pieces.
Old 08-31-2009, 08:07 AM
my87Z's Avatar
Veteran/Firefighter-Paramedic
i agree with AP, pro comp anything are crap, but i dont think you need a 3600+stall with the cam you have, i personally would go with a 2800-3200, but that aslo depends on what your doing with the car
Old 08-31-2009, 09:35 AM
well i had a 4000 in it before and i ran a 12.82. the launch was *****in but the car was so slow down the track and i would come back to the pit at 220 degrees. the tranny was super hot. but the paper work on my camshaft calls for a 2500 stall or standard tranny. just confused i know the can can do better than 12.82
Old 08-31-2009, 09:53 AM
ericnova72's Avatar
More for Less Racer
Something was wrong with the 4000 converter or you bought a cheap one. Any price less than $450 for a 3500 thru 4500 stall converter means you are getting junk. I've got a good 3600 stall in my Nova Th-400/406 engine, drive it 75 miles one way to the track, race it 8-10 passes in the mid-11's and the tranny temp never goes over 165. I've got a big 8" x 11" x1 1/2" thick stacked plate style cooler(they look like a heater core) and it is a good custom converter, not B&M, TCI, ACC, GER trash. Learned my lesson after two cheaper($250-300'ish) converters.
the history of chevy v8's savman1 Hotrodders' Lounge 43 03-02-2012 07:57 PM
Correct schematic for engine test stand? steve392 Electrical 2 07-01-2006 08:16 AM
my new engine combo predator carb guru Engine 1 01-22-2006 06:38 PM
Is this a good engine combo? 70bird Engine 17 11-23-2005 11:01 PM
Figured I'd ask here SBC INFO ENGINE COMBO SITE??? DeathByGreaser Hotrodders' Lounge 3 08-26-2003 12:33 AM
