Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - My engine crane won't fit under my frame rails? Any tips?
  #28 (permalink)
Old 07-20-2009, 03:31 PM
PapaG's Avatar
PapaG PapaG is offline
Ask me, Cause I don't know
Last journal entry: Need things to do.
They make cinder blocks and concrete blocks that look basically the same. Concrete blocks weigh a whole lot more and are a lot stronger. You could use solid concrete blocks. These are what they support houses with.
2x6, 2x8, boxes should work. Only use those to get your you truck higher. I have seen wooden car ramps people have made. I have some ramps made out of some composite that I bought somewhere.
Harbor Freight would be a cheap source for some jack stands.
Landscape timbers are cheap too.
