-   Garage - Tools (http://www.hotrodders.com/forum/garage-tools/)
-   -   My engine crane won't fit under my frame rails? Any tips? (http://www.hotrodders.com/forum/my-engine-crane-wont-fit-under-my-frame-rails-any-160385.html)
SinistrV6 06-19-2009 02:42 PM
Here's the deal. My car is bagged and I'm about to put the motor/tranny mounts in. The car needs to be sitting at "full drop" so I can determine how high to mount the motor/tranny in the rails (so as not to touch the ground).
I took some measurements and checked the angle of the rails at full drop and then set it on jackstands in the same relative position, but even that is "iffy".
Is there another method that I'm overlooking? Wouldn't be the first time I overlooked the obvious!
Thanks,
Richard
cranky1 06-19-2009 03:32 PM
Do you have a chain hoist and something to hang it from?
SinistrV6 06-19-2009 03:37 PM
No. That's the problem. If I can't get the crane to work to my satisfaction, I may have to fab up a rolling A-Frame that'll straddle the car. I hate to build that for a one-time use, though.
justold 06-19-2009 04:30 PM
Get some lumber 2x6 or 2x8 at least the length of the wheel base chafer the one end and put wheel stops at the other end stack as many as needed ,and roll the car up on them the use a straight edge on top of then to get your measurements . Or jack it up and put it on four milk crates if the car is not too heavy
daoldbuick 06-19-2009 04:49 PM
Just a variation on this. What ever you put under the tires to give you the clearance you'll need for the crane, put the exact same thing under where the motors going. Then when you put the motor in, drop it down to the clearance your looking for and Bob's your uncle. :D No measuring required.
SinistrV6 06-19-2009 06:04 PM
Good ideas. Thanks. Whatever I put under the tires needs to have a small "footprint". Not being able to work around the tires has been an issue too. I built large sawhorses to set the body on. They are wide enough to roll the chassis under but not tall enough to lift the motor. I may try to modify one of them. With no body on the chassis I dont have to lift it very high.
Cape Cod Bob 06-19-2009 08:53 PM
Another trick is if you can assemble your crane with the part that goes under the car , backwards ! Then you have to add weight to the base to counterbalance for the motor.
They actaually make this set up for industrial application where no space under the load exist. Like picking up electric motors that are set up on concrete pads, etc. :welcome:
SinistrV6 06-19-2009 11:05 PM
Not sure what I'd use for a counterweight. Maybe my Avalanche! LOL! Another good idea though. Thanks.
SSedan64 06-20-2009 12:00 AM
Speaking of counterweights, this will make you sick. > http://www.hotrodders.com/forum/fire...rd-160242.html
OneMoreTime 06-23-2009 02:30 PM
What i do is to place a plank acroos the car under the frame rails and when the pan touches the plank the engine is low enough that should give you a good idea of the height that you need for the mounts..That way you can have the car up on stands while fabricating the mounts..
Sam
hinklejd 07-04-2009 11:45 PM
Use six cinder blocks.
Jack the car up in the air, then set the four tires down on cinder blocks. Let the air out of the bags, and you'll be at the lowst point. You should have enough room to both drop in the engine/trans combo and tack in engine and trans mounts using another two cinder blocks under the engine and trans pan. I'd also use a 1/2" - 3/4" piece of wood between the cinder block and engine/trans pan to make sure there'll be enough room to clear the ground in a 'worst case' scenario.
SinistrV6 07-05-2009 07:10 AM
Thanks to all who contributed. Some good ideas. I'll let you know what I ended up doing and how it went.
jetnow1 07-05-2009 07:12 AM
lifting car
DO NOT PUT A CAR ON CINDER BLOCKS! It is a good way to get hurt or killed-they can have cracks that you would never see untill it failed under load- I have seen them come apart many times. Use 2x8 or larger lumber nailed together or better yet decent quality jackstands but never get near a car
on cinderblocks. Jim
hinklejd 07-05-2009 07:51 PM
jetnow1, I agree with you wholeheartedly. Jackstands are a much safer method of supporting an entire car than cinderblocks. But I recall the question was about how to support a chassis with no body. Four cinder blocks should be plenty enough to support a frame and suspension with no body, engine, transmission, or other weight.
Support the weight of the engine/trans with the cherry picker just to get the mounts tacked in, and pull the blocks back out.
NEW INTERIORS 07-05-2009 09:13 PM
Sorry.. :nono: I have to agree with Jetnow1 ..CINDER BLOCKS should ''NEVER'' be used when working on a car.. :nono: The thing about Cinder Blocks ''THEY WILL NEVER LET YOU KNOW WHEN THEY WILL BREAK'' And today's blocks are no where's built the way they use to be built.So please don't encourage no one to do that..It may have worked for you 99 times.But sooner or later it will get you..I have seen some break with less weight then a frame.Don't do it.. :nono:
