My engine runs much better without an air cleaner - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-04-2013, 08:11 PM
hey guys I have a basic 350 chevy bored .60 over, with around 10:1 compression, iron heads, comp cam xe 274h, performer eps manifold with a 1 inch open spacer and an edelbrock 1405 600 cfm carb
I've played with the idle mixture screw leaning out the mixture with the filter on but it still kinda runs like crap
i know i'm not running rich with a stock 1405 600 cfm carb, especially with the compression cam and headers i'm running
any who i took the the air cleaner off and my engine is as happy as can be, so much more torque and power down low, idle quality is also great now, I can really feel a genuine power increase
i know it isn't good to run without an aircleaner but my engine runs so much better without it
Old 05-04-2013, 09:18 PM
68NovaSS's Avatar
Moderator
Wiki Edits: 9
What's your question? Just sounds like you have a restrictive air filter or element.
Semper Fi
Old 05-04-2013, 09:35 PM
lol my question is if this is normal, could it be a tuning issue ?
it's a standard air cleaner with a 14x3 spectre element, it shouldn't be as restrictive as it is
Old 05-04-2013, 10:07 PM
vinniekq2's Avatar
post a picture
Old 05-04-2013, 10:14 PM
Its an oiled spectre unit correct? The only thing I can think is its over oiled. or super dirty. They actually flow really well, some say as good or better than a K&N.
I would suggest going out and buying a cheap O Fram 14x3, or bigger filter and see if there is any difference. When you get into that size filter It's unlikely your going to get any noticeable restriction.
What heads are you running? The Edelbrock 600 may be a little small for that combination.
PS I have a 383 with the same cam, vortec heads a 850DP carb and a 12x3 spectre filter... I have never noticed any difference between air filters. I have tried up to a 14x5 Air hog filter.
Ohh yeah, what are the details of the setup? any kind of snorkels? scoops on the hood? ect? Quite often you can actually loose power without a filter because of turbulence. Filters can sometimes straighten out the flow and make you more power. My guess is over oiled.
and yes post a pic please
Old 05-04-2013, 10:23 PM
I'll try cleaning the filter tomorrow and see if it makes a difference
once i took the filter off the idle shot up, i had to turn it down actually
power is up across the powerband, especially down low, crazy.
i'm running ported 601 heads with 2.02 and 1.60 valves
Old 05-04-2013, 10:57 PM
I agree with too oily/dirty and it maybe being to restrictive.
im running a spectre cone on my truck and ive used them alot in the past and the only problem ive had is when they need to be replaced but that happens with everything. I AM thinking of switching to a 4" though. Since I installed the 3" CAI it sounds supercharged and puts out better than stock but im thinking the sound is because the plumbing is too restrictive. Which is weird because ive never heard this issue with my supercharged GA or any of the previous autos and autos ive heard them being on whether being stock super or turboed. If you do drive it filterless dont do it long and especially leave it parked.
A friend of mine did that after getting home I swung over to meet with him to go cruising the next day...we go to leave and Im now sitting there waiting and waiting. Then I see him jump out of the car throwing a hissy fit so I get out go over he explains he tries it again and it just bogs. Were both stumped because we both know he cherishes that car....kinda lol. Every spare minute we had over the next 3 days we spent trying to figure it out checking and rechicking everything. We gave up but didnt quit searching online and talking to everyone we know for answers until the weekend found nothing to help us. So we started to tear it down, it has to be internal and it was...there was a huge mess of twigs grass small trash litter flowers weird crap..clogged everywhere inside of everything. First thought was sabotage....two days later we found out no one did it...it didnt hit us until we took the motor out and started tearing it down that his girlfriend finally says that she thinks its what was a birds nest....yeap sad. So we searched if it could be and we found its rare but it could happen due to the engine being warm and secluded a bird decided to make it home. We felt like idiots. It did end up costing him 3500 in parts though.
I usually go through 2 a year and only drive the truck a total of 1200 miles a year. Another indicator of upgrading lol. She sucks in a good way ;-)
Old 05-04-2013, 10:59 PM
this engine is in my jeep, nothing fancy about the hood
Old 05-05-2013, 12:36 AM
techinspector1's Avatar
Wiki Edits: 326
Well, you know what I'm thinkin'. Float set too high, fuel pressure excessive and overpowering the float/needle & seat. Motor running way rich with the air cleaner in place, leaning out a little without the filter.
The Following User Says Thank You to techinspector1 For This Useful Post:
OneMoreTime (05-05-2013)
Old 05-05-2013, 08:45 AM
RWENUTS's Avatar
If you're running a low profile cleaner base the top lid could be too close to the vent tube making it run worse.
Old 05-05-2013, 09:51 AM
malc's Avatar
Living At The Speed Of Life
How did you calculate this improvement ?
Old 05-05-2013, 07:15 PM
when I drive around at 1200 rpm or so it doesn't feel like i'm dogging it like when i had my filter on there
the car feels happy to chug along at 1200 rpm all of a sudden when before i need to be at at least 1400rpm
all my shift points have gone down too
Old 05-05-2013, 07:24 PM
life is a temporary assignment
It want's to breathe !!!!!
Old 05-06-2013, 08:31 AM
I found out many years ago that running without a paper element air cleaner can be worth 0.2 second ET.
I rather not admit how many years ago that was.
Holley Hi-Tek Air Cleaner VS Spectre Dual Cold Air Intake the82elco Engine 1 12-13-2012 03:38 PM
Runs Like Crap With Air Cleaner On - why? leejoy Engine 30 11-16-2010 06:08 PM
New air cleaner? Scotto Hotrodders' Lounge 6 02-26-2009 07:28 PM
Runs better without air cleaner NovaSS350 Engine 7 08-28-2004 07:03 PM
Air cleaner Help srd1 Engine 6 01-28-2004 05:50 PM
