My engine specs-will power brakes work? - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-27-2003, 08:51 AM
bak9jo's Avatar
New Member
Thumbs up My engine specs-will power brakes work?
My engine specs are as follows/ 355 one piece seal block;462 heads stock 1.94 /1.50 valves -bronze valve guides.forged pistons; flat tops compression around 10 to 1 cam specs are 230 /230 dur.@.50 --465 lift 102 -106 centerline.
power range of cam is 3200-6400 rpm. 350 trans 3500 stall
411 gears in a 1980 3600 pnd z28 camaro.Torker 2 intake 750 holley,or could use quadjet. will my power brakes work ok also the motor is done but have not assembled as of yet . Do you think my combination is ok what would you change?
Old 07-27-2003, 09:45 AM
Frisco's Avatar
Glad To Be Here
Are you sure that is the power range for that cam? Seems a bit high for the lift you posted.
Too much stall for a street machine and that cam. Try around 2400-2600 stall.
Power brakes should be fine with the cam specs you posted.
Old 07-27-2003, 11:47 AM
bak9jo's Avatar
New Member
re:cam lift
Yeah about the cam I thought the same ,but I was told by crane that it is right .The lobe sepperation and center line being like it is caused the high rpm.Check itout in jEGS it is a
CRANE ENERGIZER 286H CAM PART #270-100182
286 ADV.-465 LIFT--RPM RANGE IS 3000-6400
CHECK IT OUT also my car is not all street just a little cruising more drag race we live 5 mins.from track i also have a big trans cooler to help with stall.I am just curios about brakes will vacume can helP.CAM ALSO SAYS MID -UPPER RANGE TOURQE LTD.STREET&BRACKET ROUGH IDLE
Old 07-27-2003, 09:29 PM
If your brakes need a bit extra boost you can run a Vacuum can or if it needs more than that you can get a pump that will give the system the kick it needs. www.ecihotrodbrakes.com
Old 07-27-2003, 09:43 PM
redcamaro4spd's Avatar
drive it like you hate it
hey man, what kinda power u producing with those 462 casting heads? I was gonna use them for a little less radical setup on my car, but everyone said that they werent very good performance heads...
Old 07-27-2003, 10:09 PM
E.T. divided by $ spent= Speed
redcamaro 462s are decent performance heads,just nobody wants to say it anymore cause theve got AFR on the brain.The performance gain to availabilitie factor is bad but if you've allready got a set of castings use um there still decent,or send um to me for X-mas.
bac9jo,Your set up sounds good to me.Sounds high 12ish to me.Use the holley 750.(Once the car is running,run the Q-jet over in a repeated fashion till dead.)
I'm not sure but you might need that vacuum can reserve thing mentioned above.Competition cams makes um.I'd drive it first and see befor I bought anything myself.
Old 07-28-2003, 10:01 AM
every set up is a little different but that cam dosnt seem to big best thing is try it out first before buying anything you should be around 10 inches of vacuum at 1000 rpm
Old 07-28-2003, 10:05 AM
bak9jo's Avatar
New Member
well anyone know were i can find manual brakes for the 1980 z28 every were i look brings up junk i will convert it over also anyone know of or have parts for my car e mail me thanks
Old 07-28-2003, 10:24 PM
Early 2nd-generation (1970-71) Camaros came with manual disc brakes as standard equipment. Maybe a 71 manual master cylinder & linkage would work.
