My family gorcery getter 72 chevelle w/l98 and 700r4. - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-05-2006, 05:50 PM
hey guys whats going on?I am looking for some some help I am doing the 350 to 700r4 swap but I need help does anyone make a mount kit for this swap? Do I have to shorten the drive shaft?I am using a 700r4 from an 85 vette and the trans mount are two bolts that go thru te rear side of the trans and it mounts up and down.what can I do?
Old 07-05-2006, 07:51 PM
wckd_1,
Measure your 350 and then measure the Vett transmission. The difference should be near 1/2 to 3/4 of an inch difference and if it is you can use your old driveshaft, IF the splines are the same count on the output shafts. If not you will need the slide yoke that will fit the Vett trans.
As for the rear engine/transmission mount crossmember, you can use your old one but re-drill the mounting holes where it attaches to the frame. That is what I did on my 76 GMC Sprint when I changed it over to the 700r4. As for the difference between the way the transmissions mount to the crossmember this is what I would do. I would use a short piece of angle iron bolted to the trans solid, then use a normal rear transmission mount. By grinding the angle iron you can make it fit the shape of the tailshaft like a glove. And since you are going to move the crossmember anyway this would be an easy fabrication job.
Good Luck
Scholman
Old 07-05-2006, 09:09 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
If you have a vette tranny , you can not use the vette tail housing for mounting. You need to find a tail housing with mounting holes on it.
the photo shows a vette trans & output shaft with the style of tail housing I am talking about. The vette tranny case does not have a mounting pad area on it for a mount to bolt on.
You will also need to move the speed-O plastic gear ( if you use that) forward to the front hole for the speed-O gear clip pin.
