Horsepower is how fast you hit the wall. Torque is how far you take the wall with you. Midnight Sun Street Rod Association |
One thing I didn't say is your need to over time acquire tools and equipment.I know what I started with and what I have now makes a world of difference.Just to have a good mix of nuts and bolts can cost a tidy sum.
If you want to have the most fun with nitrous,, build a cheap *&^% motor that you won't cry over if/when it fails. It will only fail from a tuning mistake.
If a $7000 short block with all the goodies, fails, How much fun is that. but if a $800 350 short block fails,, you can laugh and learn and do it again. Learn to build you own simple basic 350's A near stock motor with a big cam, good heads etc will go like hell and take a ton of nitrous. couple keys high rpm from launch to finish. Do not launch at a low rpm on nitrous. high stall converter. Big duration cam that can rev and shifts the power and cylinder pressure up high. Solid flat tappet is fine. Get the exhaust out. big exhaust, big exhaust duration. Good heads You need flow good basic valvetain,, it has to rev Good high octane fuel 110+ race gas. Don;t be afraid to hit it hard. It will take it. Large piston rind end gaps, larger piston to wall clearance Watch the timing on nitrous... nitrous speeds up the combustion. A tunnel ram works really well with nitrous.. its the tuning mistakes that hurt the motor, not the amount of nitrous good fuel is essential for big shots. |
Will 110 save me some money on parts or is it more of a safety thing. For example will running 110 with a good top end make it capable of running a cast assembly? Last edited by kentactic; 11-23-2012 at 08:00 AM. |
Then a time frame of only"9 months". I am thinking it is going to take longer than that funds wise. But a price point of $3500. And him saying that if $3500 isn't enough,"I'll have to extend the build time". To that end I agree. So here is what I am thinking.Certainly there are still new developments in first gen SBC's all the time.But all those are being overshadowed by the LSx series engines.Especially LSx series engines with power adders.I just don't want to suggest a first gen that he is spending as he can to have finish and over time have built,that gets run over with the tech from a LSx series engine.Is it going to cost him more??. Yes,yes it is. But as he can check to check build it,the long term investment would be better and closer to the current tech going on. I then is a matter of commitment to the build,but I believe a positive suggestion. |
The guy doesnt even have a car to put the engine in,,,, He should take the 3500 and buy a clean V-8 late 90s Camaro and take it to the track the day after he buys it.On street tires and stock trim it will get him down the track with very little costs. Buy tires as required and update and improve as budget allows...
Building a gen 1 small block for maybe a fox car in the future? seriously? |
To each their own but screwing around with a clunker with unknown cans of worms every where dosent sound like much fun. Sounds like more of a money pitt then just building it totally right the first time. Why spend money on parts on a running car i dont plan to use? My dodge neon is as fast as a stock 90's camaro...just saying.. |
I hope you are successful in your quest. At mission raceway we have an old Mustang with a 355 chevy in it.mid 10s,beautiful car--expensive build.
We also have a 77 Camaro with a 383,the kind with the distributor in the front of the engine.I think its a 13 second street car,low budget,just did it because he thought he could. Engine swapping is what hot rodding is all about. some ideas are practical,some are just whims.Can it be done+yes,then ask why you would do that? are there better ideas? what will this project cost when done? what will you have when its finished? what will it be worth? My project is a very good example of what is not a good idea,but I like it,so I did it. Hope that w/e you have at the end is what you really really want |
This may sound like a VERY strange idea, but I'd build your car to handle that power, then build a good turbo and induction system. Run that on a stock long block with maybe a solid flat tappet cam swap. If and when it pops you just need another $300 long block. BTW, for 600fwhp you only need a modest 10-15 pounds of boost. Turbos are a LOT easier on an engine than nitrous too.
Its about the cheapest way to get into the 10s and STAY there. |
Yes i appreciate the idea. The Neon thing wasnt directed at you. If i knew what you know i may very well go that route. But i know what i know and that aint much in the specifics of these motors. My motto is simplicity is ideal. Ive got to go with what i know.
well now thats a trick becasue i have done this for years now and i always start with a running car. That has many advantages for me. You never know what parts you are going to need until you get it built. so having a complete car you know you have that funny bolt or braket that is going to stop the project if you cant find it. Also cost should not be much more they are cheap these days. Finding one running will probably be the same price. Fox body? are you going for a 10.5 outlaw or one of the other 10.5 race class of car. Mustangs are good and very cheap. You can get one for few hundred bucks. Chevy motor is cheap and easy to build and will make your mustang race worthy if done right. You should know that stock mounting points for suspension will up the cost of the build. If you are just bracket racing a stock camero may not be a bad way to go. they are not that heavy and either way you will be reworking the rear to get it right. FYI I ripped the torque boxes out of my 86 SVO with a four banger and slicks at the track. Be prepared for some stuff to break. i never figured the control arms could push the floor of the car out with less than 300 hp. |
| 350 Motor 350/400 HP build | smokeb1 | Engine | 6 | 01-18-2012 11:18 AM |
| 350 build questions, looking for 300-350 hp | Jaiden2010 | Engine | 18 | 06-23-2011 07:49 AM |
| 350 Build Up Please Look Over | SBC-S-15 | Engine | 14 | 07-11-2004 06:52 AM |
| 350 build | Captnscotty | Engine | 15 | 09-11-2003 09:04 PM |
