My first 350 build - Page 7 - Hot Rod Forum : Hotrodders Bulletin Board
  #91 (permalink)
Old 11-25-2012, 07:59 PM
Originally Posted by ap72 View Post
Hey, when you're spending someone else's money why stop there?
The assault heads can do very well for the price.
Ya i figure i can get those heads completed for about 1k. That seem right?
  #92 (permalink)
Bye Jerks
and they were sold in a pair and the darts are individually...
K, that part I missed. I thought it was for EACH head.
  #93 (permalink)
Old 11-25-2012, 08:09 PM
Banned
Seems like you must be buying some really fancy parts for them. If you wanted to you could complete them for around $650 for everything with good parts.
  #94 (permalink)
Old 11-25-2012, 08:14 PM
Originally Posted by 632Mantis View Post
Post a link so we can check it out.
Thats not a bad price for an all-forged complete assembly, depending on the brand of parts in the kit.
Probably Scat or Eagle i'm guessing.
Its not a kit more me piecing a kit together. I think im looking at the right stuff. This is just me clicking around guessing the exacts of what i need. The darn machinist says i should run 6'' rods. Im not sure if that means i am building a 383 stroker (i dont think i want to do this) or if it makes it a 355 or what...so anyways... theres the main parts. So anyways i through the 383 crank in there...
-Rods
SMALL BLOCK CHEVY 383 350 406 4340 6" Connecting Rods - KMJ Performance
-Pistons
Sbc Small Block Chevy 350 Forged 6in Rod Ft Pistons Set - KMJ Performance
-Crankshaft
SBC CHEVY 383 4130 Forged Steel Crankshaft 350 6" Rod - KMJ Performance
  #95 (permalink)
Bye Jerks
Keep your options open:
BluePrint Engines GM 383 C.I.D. Stroker Base Dressed Crate Engines BP38313CTC1 - SummitRacing.com
  #96 (permalink)
Old 11-25-2012, 08:20 PM
I see. All my guesstimations are based on what random parts i click on, on the internet coupled with the "its going to cost you millions of dollars to do this 600hp motor!!!" people. So i figured 1k... im really hoping this machinist guy can get me grounded better on wth i need to do this right at a good price. He seems to know his stuff.
Like i said im all ears. If you guys want to link all the parts youd use in your head i will totally look it over and then show my machinist and if he concours perhaps that will be the route i will go.
There seems to be two camps on this forum. The "it costs millions" guys and the "its not very expensive to build" guys.
Im not sure which is closer to reality. I need to build it right and reliable and tough for nitrous. But at the same time im not looking for top of the line parts either.
  #97 (permalink)
Old 11-25-2012, 08:21 PM
Banned
-Rods
-Pistons
-Crankshaft
I'd steer away from ProComp rods, maybe look at some Scats for a budget piece. Also the Blueprint engines listed- I have not used them but I have heard of problems with them, not as bad as Jasper but problems nonetheless.
  #98 (permalink)
Old 11-25-2012, 08:23 PM
Alrighty ill look at the scats thanks.
  #99 (permalink)
Old 11-25-2012, 09:15 PM
vinniekq2's Avatar
you dont have a car,LISTEN to ap72,the cheapest 600 hp engine is a turbo 5.3,find a car for that engine. Gen 1 is not that practical anymore
  #100 (permalink)
Old 11-25-2012, 09:55 PM
techinspector1's Avatar
Wiki Edits: 326
Although it's hard to accept, you're correct.
  #101 (permalink)
Old 11-25-2012, 10:29 PM
Originally Posted by F-BIRD'88 View Post
All my street nitrous motors were stock crank, stock rods, stock block.
Most were cast pistons. I personally have never hurt a piston with nitrous.
And I have hit them with a lot more than you need to even consider, to go fast.
All you need is a decent 350 with forged flat top pistons. 5.7 rods.
Spend your money on good high octane gas and stuff that will make it go fast.
Cylinder heads, fuel system etc. The Brodix IK200 is a good head for this.
If you want to hit it hard with nitrous, using (good) pump gas. (as hard as practically possible) build with a conservative modest compression ratio. The nitrous makes the power.
So your saying a cast crank and cast rods will hold up to 600hp? I ask because even the forged I beam rods say they are only good for 550hp.
  #102 (permalink)
Old 11-25-2012, 10:33 PM
Seems everything i get into is always on its way out. The 350 was cool for 60 years and the second i get into it its on its way out. I cant win. Im totally understanding that new technoligy rules. I use to do the 4 cyl. thing. But all the computer controlled stuff seems like a huge can of worms. It seems like its going to complicate the heck out of this project.
Am i wrong in my assumptions?
  #103 (permalink)
Old 11-25-2012, 10:41 PM
prostreet6t9's Avatar
Differential/Driveline
With a 250 shot your pushing it and stand a chance of burning the piston with cast. It just gets to hot with the juice.
  #104 (permalink)
1Gary's Avatar
Last journal entry: 383 dyno sym
Some threads reach a point where you just have to repeat yourself.
It isn't reasonable that someone else's adventures have to made into your own.Our professional built race engines are built to handle more,alot more,than they see.
And after all it's your money.................
  #105 (permalink)
Old 11-25-2012, 10:45 PM
As far a MPG the late model stuff cant be beat. If I walk down the staging lanes at a track I can probably count on one hand the cars using LS or Vortec stuff.
I think the GEN 1 stuff still rules the track.
My next project small block 350 chevy smokeb1 Engine 0 01-18-2012 08:53 AM
350 build questions, looking for 300-350 hp Jaiden2010 Engine 18 06-23-2011 07:49 AM
350 Build Up Please Look Over SBC-S-15 Engine 14 07-11-2004 06:52 AM
350 build Captnscotty Engine 15 09-11-2003 09:04 PM
