Ok so ive decided to build a SBC 350 for nitrous. The goals are a 200-300 shot. For now i guess let me just tackle the bottom end as it will be a while to fund this motor and right now im at phase one, having the block machined, And purchasing a rotating assembly. The block is an "010" 68-76
4-bolt main.
This car will be a track car with very minimal street driving. I dont even have a car as of yet. First i plan to build the motor and then go from there.
I beleive i need to run an all forged rotating assembly correct? I also beleive i want a 10:1 or less compression (Id prefer to run 91). I was told for my power goals of 600+hp i will have to run H beam rods, This correct? Also the machinist guy tells me i should balance the Rotating assembly. Is this a power thing or a reliability thing? I want the motor reliable but i cant afford to do every little trick thing to make maximum power. Anything else i should look for or watch out for is much appreciated.
Also this is my first post so hello everyone. Im not here to suck up your info and scoot. If all goes well some day i can contribute usefull info of my own. Maybe this thread can continue throughout my build from start to finnish.
-Kenny
4-bolt main.
-Kenny
